Postby Phil349 » Sat May 14, 2011 12:46 pm
Excellent stuff!!!
I aggree we should have the shafts drilled and use a castle nut and split pin.
The circlip groove is only about 1.5/1.6 mm high on the standard DMC joint, and that is the measurement I modified my elise ones to also. 2mm would have been too large.
Just a question on point 3 Darren, the bottom plate thickness. If the spring tension is pulling the on the joint upwards, trying to pull the ball from the socket, how can the bottom plate bend downwards? maybe when driving and the suspension is moving it could happen over time?
Phil349
VIN #: 1128
Postby Dan 6511 » Sat May 14, 2011 12:49 pm
I just feel that drilling a hole is just going to weaken the thing. If I were to drill a hole I might do the nut up then drill through the nut and the shaft together and insert a roll pin. I think nyloc would be just fine though personally.
Postby arranj » Sat May 14, 2011 12:57 pm
The castle nuts/split pin was a recall - page 4 here: http://www.dmcnews.com/bulletins/SC-03-1.82.html
But I'm not sure Nylock nuts were used back in those days - and I can't see the problem with a Nylock nut - maybe even two just for the fun of it?!
It's a personal preference thing - it's not exactly difficult for the end user to drill themselves? 97p for a nut from here: http://www.namrick.co.uk/acatalog/U.N.F._Nuts.html
Postby Phil349 » Sat May 14, 2011 1:22 pm
Dan 6457 wrote:I just feel that drilling a hole is just going to weaken the thing. If I were to drill a hole I might do the nut up then drill through the nut and the shaft together and insert a roll pin. I think nyloc would be just fine though personally.
The drilled hole in the shaft is above the nut in effect, at the castleated area of the nut, so above the real used contact area with the shaft where you need the shaft to have strength. If you see what I mean so wont weaken the actual connection between nut and shaft.
A proper castle nut would have as much contact area as a standard nut where its threaded, then the castlated part would be extra on top, so taller over all. The castle nuts that came with the special T joints were very low profile so I didnt use them and got alernative ones.
I would think drilling through the actual nut and shaft together as you describe and sticking a roll pin through will really weaken it overall at the point where you need that strengh.
Nylocks probably would be fine really, but castle nuts can be even better. I think the recall was because they found some nuts were coming loose on their own but I dont know if these were normal nuts or nylocks.
Its not easy to drill the shaft on the car as access can be tricky, better to have the shaft pre drilled then installation will be nice and simple. :)
Phil349
VIN #: 1128
Postby Daniel Shane » Sat May 14, 2011 1:30 pm
F**king great news.
And it's made in the UK so that's even better !!
I'd go for the nylock nuts and not worry about drilling. All modern cars use nylocks and it make find a replacement nut easy
Postby RobvdVeer » Sat May 14, 2011 3:10 pm
Daniel Shane wrote:All modern cars
Quoted for effect
Postby A Van » Sat May 14, 2011 4:53 pm
As a DeLorean is just part of the ' Darren Collins Collection ' it doesn't get used that much so we think it would be prudent to also fit a set to a car which is used a lot, step up Dan Stacey.
Postby jerzybondov » Sat May 14, 2011 5:59 pm
If Dan can't be arsed to change his, I'm happy to be a guinea pig - my car's going to be piling on the miles this summer...
Postby Dan 6511 » Sat May 14, 2011 6:12 pm
Well I want to change to these new type anyway as I don't trust the VW ones.
While I'm in there Im gonna change out the polybush for a rubber one as its crap. Now we need to find a UK source of these too :lol:
I'll change my uppers as well 'while im in there', they are vauxhall viva right?
Postby arranj » Sat May 14, 2011 6:26 pm
Yes Dan: viewtopic.php?f=27&t=1902
We have NOS ones in stock too: viewtopic.php?f=66&t=589
