Trunk release
Trunk release
Postby A Van » Sun May 17, 2015 4:41 pm
Guess who's trunk release cable broke.... And hadn't got round to running an emergency one....and was en route to a wedding.... And the presents were in the trunk.... And no fuel flap
Re: Trunk release
Postby Horsebox » Sun May 17, 2015 4:52 pm
That's rubbish. Bet it made a good anecdote at the evening bash though. Pressies still in there!?
Horsebox
VIN #: 06042
Re: Trunk release
Postby Admin-bloke » Sun May 17, 2015 5:23 pm
That's my story not to buy presents! The tightness-force is getting strong in you ;)
Re: Trunk release
Postby A Van » Sun May 17, 2015 6:21 pm
The break was at the latch end
Re: Trunk release
Postby jerzybondov » Mon May 18, 2015 2:21 pm
How did you get round it Al?
Re: Trunk release
Postby A Van » Tue May 19, 2015 8:55 am
Well my dad had a go with some stiff rod while we got ready...
No luck
Got to church explained to Tom I had a plan to use one of his cars to form the wire correctly and try to go in through grommet under dashboard.
If all else failed I was going to drive Toms stock car back and leave mine there and sort it another time.
I got changed after the meal and after two hours got it open, by going in through the grommet. had some help from another guest as well!
Repaired cable and ran a spare lol
Re: Trunk release
Postby Manxmann » Tue May 19, 2015 4:55 pm
Had this problem about 6months ago, my solution was:
Raise the front of the car and place securely on axle stands.
Lying under the front drivers side locate the round access hatch above the brake fluid reservoir.
If fitted push out the hole cover and using a pole/stick, I used the jack handle push up the boot lining board until you can see the front latch through the hole.
Using a 2nd bar equipped with a hooked end reach through, hook the latch and pull like an absolute b@rstard.
If you believe in a higher entity prayer mike be good at this stage :)
The Manx 'D' - VIN 17152
Manxmann
VIN #: 17152
Re: Trunk release
Postby Manxmann » Tue May 19, 2015 4:56 pm
P.S. I had a spare, thanks to Mr G, it snapped sums him up really.
Manxmann
VIN #: 17152
Re: Trunk release
Postby A Van » Tue May 19, 2015 6:41 pm
Manxmann wrote:Had this problem about 6months ago, my solution was:
That was going to be the next plan!
Re: Trunk release
Postby A Van » Wed May 20, 2015 12:58 pm
Manxmann wrote:P.S. I had a spare, thanks to Mr G, it snapped sums him up really.
No comment
