Page 1 of 2
I have an engine!
PostPosted: Wed Aug 26, 2009 8:41 pm
by tommy boy
Picked up today:
Re: I have an engine!
PostPosted: Wed Aug 26, 2009 8:46 pm
by arranj
Great news Tom.
Is there some reason why this doesn't look anything like a DeLorean engine?!
PostPosted: Wed Aug 26, 2009 9:33 pm
by tourettes tony
flywheels on the wrong end :shock: TT
PostPosted: Wed Aug 26, 2009 10:09 pm
by arranj
Seriously though, you're swapping a few parts here? What's the difference between this and the engine we all have? :?
PostPosted: Wed Aug 26, 2009 10:31 pm
by DeLorean Cars
Steel covers and a flex plate (automatic) with carbs. Probably a 2.6 unless it's from a Pug (don't have much experience of them). The only 2.8 carb that I know of is a GTA atmo and they're all 5-speeds
PostPosted: Thu Aug 27, 2009 12:59 pm
by arranj
Yep - I think it's from a Peugeot, although not from a Dakar Rally car! :mrgreen:
PostPosted: Fri Aug 28, 2009 8:51 pm
by DMCDELLBOY
may be a late 760 dissy in a diffrent place i think ;good to get old of now ;i think engines are getting very scarce now i have a complete engine out of 262 volvo bertone for a just in case .
PostPosted: Sat Aug 29, 2009 8:00 pm
by tommy boy
Sallys watching The x factors on telly so i thought i'd give you a bit of an update on the engine situation.
First off, it's off a peugeot 505 auto, which has been rebuilt with new chains, cams and other very interesting bits n bobs. i just picked up a new clutch for it today as well for the bargain price of £100
This morning i started to strip the knackerd engine down, removing the sump sandwich plate and a pipe or 2. The block is a bit of a bodge i may turn it in to a coffee table and get my own back.
As my mornings start at around 2pm i didn't get chance to put the old bits on the new engine, i'll do that tomorrow starting at the crack of dinnertime.
The good news is that while i was taking all the various nuts and bolts off i didn't break, thread, round off or lose anything at all, even the exhaust studs came out ok :shock:
Here are some piccies of the eventfull day
BTW the dizzy will need to be changed for my one as peugeot used a computer thingamabob instead of the volvo/delorean setup
and the other item to note is that the engine will only run on carbs as there are no injector holes :o
OH and its got a mecanical fuel pump running off the other cam shaft, its up to me if i want to use this or the elrctric one i installed in the fuel tank
PostPosted: Sat Aug 29, 2009 8:05 pm
by Admin-bloke
If you get me the code from the carburettor (solex, weber, stromberg etc) then I can get the info for you.
PostPosted: Sat Sep 12, 2009 8:35 pm
by cineman
nice thread :)
post a lot of photos of your engine transplant :) I like to see other PRV's in the delorean. So will you keep it carbed :) ?
What the original engine had? Will you put the lower crankcase taking it from the original one?
