Page 1 of 3
Volvo 760 Strip Down
PostPosted: Sun Feb 14, 2010 7:37 pm
by Dan 6511
Today I got my volvo out of my lockup, it started straight up so I drove it up to the house then did this to it:
Re: Volvo 760 Strip Down
PostPosted: Sun Feb 14, 2010 7:38 pm
by Dan 6511
PostPosted: Sun Feb 14, 2010 8:03 pm
by tourettes tony
nice one mate :D , hang on to the expansion bottle as well TT
PostPosted: Sun Feb 14, 2010 11:37 pm
by Admin-bloke
Nice work there Dan, keep that beige ignition amplifier on the wheel arch near the ignition coil !
Keep the idle ecu too, should be same as the D
I would also strip the relays and fuses lamps if they are the same types too !
I bet it won't take you long to strip the main volvo bits down like light units, interior, wheels etc. and sell it on ebay !
PostPosted: Mon Feb 15, 2010 7:28 pm
by jerzybondov
How long did it take you to get the engine out Dan? Good work!
PostPosted: Mon Feb 15, 2010 9:43 pm
by Dan 6511
I think it took me about 4 hours to get it out. The hardest part was getting the gearbox off the engine. Having to climb under the car with no pit and undo fiddly little bolts for the flywheel cover, as well as the main big bolts that were hard to get leverage on while laying on my back.
PostPosted: Mon Feb 15, 2010 9:51 pm
by tourettes tony
you did ok dan :D TT
PostPosted: Thu Feb 25, 2010 12:11 pm
by bandit
Hey Al, he did by im' sen
PostPosted: Sat May 01, 2010 4:01 pm
by Dan 6511
Started swapping the sandwich plate over today to make it into a delorean engine. Can't bolt it up though as I need some RTV sealant and a new o-ring :roll: Anyway it looks more like a delorean engine now :)
PostPosted: Sat May 01, 2010 4:02 pm
by Dan 6511
