Hi All
Hope you all had a great xmas and new year, bit more of an update for you all, i started off bt going through all the parts i got with the van...
- 20191128_105336 (Medium).jpg (401.58 KiB) Viewed 6398 times
Since these have been in my trailer they have gathered some leaves, i was too hopful about most of this as its all been outside for years, the engine i knew when i got it was seized so at this point i didnt know if it was savable or not, so i went through the various parts that were there and this is what i was left with ...
- 20191129_153218 (Medium).jpg (388.98 KiB) Viewed 6398 times
the engine had a gearbox on it but it was so rusted on i had to destroy it getting it off..
- 20191129_130916 (Medium).jpg (285.85 KiB) Viewed 6398 times
I ended up unbolting the clutch to get it apart
So i started on the engine ...
- 20191129_233842 (Medium).jpg (223.44 KiB) Viewed 6398 times
not looking good
- 20191129_234031 (Medium).jpg (302.35 KiB) Viewed 6398 times
shagged i think is the term...
- 20191129_234523 (Medium).jpg (385.5 KiB) Viewed 6398 times
In the hope it could still be saved i tried to get the head off, I tried everything to get it off, no luck, i even set alight to it ! ...
- 20191205_002607 (Medium).jpg (179.27 KiB) Viewed 6398 times
So in the end after 3-4 goes trying to get it off i gave up and managed to source a good used 850cc engine and box, the same as Dan has for his...
- 20191221_124601 (Medium).jpg (264.94 KiB) Viewed 6398 times
Ive also got some rear lights ...
- 20191223_110430 (Medium).jpg (186.75 KiB) Viewed 6398 times
and an original fuel tank...
- 20200102_205334 (Medium).jpg (230.41 KiB) Viewed 6398 times
So last night i finally started on some fibreglass repairs, i started with the bit split on the passenger side front wing area...
before
- 20200102_205445 (Medium).jpg (193.04 KiB) Viewed 6398 times
I then opened up the crack to get some nice clean edges on the fibreglass
- 20200102_213529 (Medium).jpg (177.86 KiB) Viewed 6398 times
Then from inside i cleaned off all the rubbish filler and crap from a previous repair...
this was before ...
- 20200102_205459 (Medium).jpg (184.85 KiB) Viewed 6398 times
all prepped up ...
- 20200102_215335 (Medium).jpg (273.57 KiB) Viewed 6398 times
And finally with 2 layers of fibreglass ...
- 20200102_224921 (Medium).jpg (321.47 KiB) Viewed 6398 times
- 20200102_231546 (Medium).jpg (215.81 KiB) Viewed 6398 times
I then moved onto the lower half of this panel ...
- 20200103_153419 (Medium).jpg (200.64 KiB) Viewed 6398 times
I clamped a length of wood on the outside to try and keep things straight..
- 20200103_153351 (Medium).jpg (228.5 KiB) Viewed 6398 times
Fibreglass cut to fit ...
- 20200103_153449 (Medium).jpg (301.43 KiB) Viewed 6398 times
With resin added...
- 20200103_164839 (Medium).jpg (220.6 KiB) Viewed 6398 times
Its now one piece again..
- 20200103_170058 (Medium).jpg (184.05 KiB) Viewed 6398 times
It doesnt look pretty at the moment but I'm going to do all the structural repairs from behind first then all the fibreglass filler repairs after.
I was very surprised how strong this is now
Finally this turned up today ...
- 20200103_125928 (Medium).jpg (131.22 KiB) Viewed 6398 times
Thats where im at so far
