clutch master cylinder tec
Postby DMCDELLBOY » Thu Sep 08, 2011 8:42 pm
yer weekend at jules, clutch master cylinder kit from D, Howarth, the job card says 26 hours to fit so lets see if we can beat the time or get close.
DMCDELLBOY
VIN #: 11075
Re: clutch master cylinder tec
Postby tourettes tony » Thu Sep 08, 2011 9:03 pm
should be 26 minutes ;)
Postby A Van » Thu Sep 08, 2011 9:25 pm
Lol Malc, take pics!!
Sent from my Transformer TF101 using Tapatalk
Postby Darren C » Fri Sep 09, 2011 9:58 am
2hrs to do,
24hrs to recover from the frustration, of the stupid position and no access to get to it.
Total 26 hrs
spot on ;)
Postby bandit » Fri Sep 09, 2011 10:07 am
Darren C wrote:2hrs to do,
Total 26 hrs
spot on ;)
That's about right Darren. I did my own after it started leaking in Belfast. I think Malc is including in the job card time, beer, wine, food & then the cheese & port, if we get that far!
Postby bandit » Sun Sep 11, 2011 7:45 pm
Image. On inspection looks like it's been off before, note odd bolts
Postby bandit » Sun Sep 11, 2011 7:48 pm
Image. Accessing the pipe off the master cyl.
Postby bandit » Sun Sep 11, 2011 7:49 pm
Image. Malc supervising
Postby RobvdVeer » Sun Sep 11, 2011 7:51 pm
bandit wrote:Image. Accessing the pipe off the master cyl.
I have these 6-sides bolts on the master near the pedal area, and they are a hell to work on, because there no proper room for a socket set.
Number two, the outside bit (with the piping) doesn't look like it was changed recently.
I must compliment you on the cleanliness of the master cylinder. Fucked up or not, it looks clean.
Postby arranj » Sun Sep 11, 2011 7:57 pm
Never mind that - how was the cheese and port?
