Lower engine cover STAINLESS SUPPORT UPGRADE!
I have had it with that crapy lower engine cover. Every time I open is like I am about to open an egg packaging.
Then it just rests and curves up..
Then some idiot won't notice the support and presses it down... Crack!
So I did a little research and designed a stainless support upgrade with logo!
Here is what you get.
And this is the outcome
Upper
Lower
NOTE:
Drilling of the lower engine cover is required and minimum installation skills;)
Got 4 sets ready to go on which I did the hole drilling.
May need a slight adjusting. Next set will be machined to perfection.
These 4 sets are cheaper.., only for 100GBP SHIPPED
NEXT LOT WILL BE 150GBP
WILL POST A HOW TO INSTALLATION GUIDE ON ANOTHER SECTION
[So I did a little research and designed a stainless support upgrade with logo!
Upper
Lower
NOTE:
