Postby Daniel Shane » Tue Apr 02, 2013 6:36 pm
Starglider wrote:Thanks for the encouragement guys, with luck it will be ready for at least one event this summer.
Manxmann wrote:So you going to need a 'completely' separate hydraulic line and callipers to achieve this, is it really worth all the hassle? How are you going to modify the rear hubs for the 2nd calliper?
Honestly I have no idea, Martin advertises the brake upgrade as 'fully fitted' so I assume he has a plan, but I don't know the details. Ed Uding has apparently been working on a fully compliant four wheel brake upgrade kit, but hasn't had the time to complete it.
The brake kit comes from Hi spec Motorsports in Dartford, just down the road from me. They sell directly to the public
Postby Starglider » Thu May 16, 2013 9:06 am
Just an FYI for anyone thinking about putting the Quaife ATB limited-slip diff in their DMC-12; as supplied it works ok in front engine orientation but doesn't fit when flipped over for rear-engine use. The diff rubs against the UN1 casing and doesn't mesh properly with the output shaft as shown here;
Fortunately it's fairly easy to fix with a little machining of the casing, Kevin @ GTO Racing did this for Martin's build and Chris's transmission guy is replicating that for mine.
Starglider
VIN #: 12306
Postby Darren C » Thu May 16, 2013 9:32 pm
That's not Welsh Kevin is it? Works at GTO near Reading?
Postby Starglider » Fri May 17, 2013 5:43 am
Darren C wrote:That's not Welsh Kevin is it? Works at GTO near Reading?
That's the one.
Starglider
VIN #: 12306
Postby Darren C » Fri May 17, 2013 8:32 pm
Nice Bloke.
I've had the priviledge of visiting his home in South Wales, he has some truly amazing cars there. :thumbsup:
I bought a load of vintage Ferrari parts from him.
Has a complete collection of original works rally Renaults to name but a few.
Postby Starglider » Thu May 23, 2013 8:11 pm
Here's the VIN plate;
Didn't have original horns so fitted a pair of new Bosch units. They sound good but draw about twice the current of the originals, so spliced in a horn relay along with John Hervey's lighting circuit relay (to prevent arcing destroying the switches);
Obviously some cleanup to do once all the wiring is in (still quite a lot more to go).
Starglider
VIN #: 12306
Postby Starglider » Tue Aug 13, 2013 12:17 pm
Attempted to take the car over to Ed Uding for engine install, but the back of the trailer was not properly secured and tragedy struck. We managed to cram most of the parts back into the trailer...
Starglider
VIN #: 12306
Postby A Van » Tue Aug 13, 2013 3:40 pm
Hhaha!
You had me going there for a while had I not already known Ed has it
Postby Starglider » Tue Aug 13, 2013 8:06 pm
A Van wrote:Hhaha!
Yeah ok it's actually a load of damaged parts Chris wanted hauled back to his workshop. :) I'm sure he'll get it all cleaned up and good as new eventually.
Here's the actual car being unloaded at Ed's;
As promised, the Vehicross ended up as the DeLorean tow car, worked well, nice and stable.
Engine is ready to go in, but Ed's pretty busy so could be a couple of months before it's fully installed & tuned.
Also asked Ed to put on his LCA bracing struts. He's got some cool stuff in development over there, had to swear not to blab about it and spoil the surprise. :)
Starglider
VIN #: 12306
Postby Starglider » Sat Oct 19, 2013 12:03 pm
Still making slow but steady progress. Seat covers (logo is a callback to the company who did the original turbo DMC-12 development);
Stainless exhaust tips (still need a bit of cleanup);
Starglider
VIN #: 12306
