Look what I've got back....
Re: Look what I've got back....
Postby InoX » Sun Apr 16, 2017 1:27 pm
ImageIMAG0624 by Justin Drexler, on Flickr
ImageIMAG0625 by Justin Drexler, on Flickr
ImageIMAG0629 by Justin Drexler, on Flickr
ImageIMAG0630 by Justin Drexler, on Flickr
Think I may have found the two inches I need
ImageIMAG0631 by Justin Drexler, on Flickr
you can see where the pipe was connected to the hose for whatever reason it was pushed onto the metal pipe a good 3". I'll have a play tomorrow to see if i can get it right.
Other news:
ImageIMAG0616 by Justin Drexler, on Flickr
sanded and painted.
ImageIMAG0638 by Justin Drexler, on Flickr
ImageIMAG0617 by Justin Drexler, on Flickr
ImageIMAG0618 by Justin Drexler, on Flickr
ImageIMAG0620 by Justin Drexler, on Flickr
ImageIMAG0621 by Justin Drexler, on Flickr
ImageIMAG0623 by Justin Drexler, on Flickr
ImageIMAG0622 by Justin Drexler, on Flickr
ImageIMAG0633 by Justin Drexler, on Flickr
ImageIMAG0634 by Justin Drexler, on Flickr
ImageIMAG0635 by Justin Drexler, on Flickr
ImageIMAG0636 by Justin Drexler, on Flickr
ImageIMAG0637 by Justin Drexler, on Flickr
Rad should be going back in tomorrow. If i can ask a stupid question: the new rubber bushes I got for the new rad, I they go between the rad and the brackets, don't they and the bolt head sits on the bracket?
Postby InoX » Mon Apr 17, 2017 11:04 am
Am I supposed to have four rad mounting rubber washers?
If I do, why did I only order two... :oops:
Postby InoX » Mon Apr 17, 2017 1:33 pm
Got the pipes to fit.
ImageIMAG0645 by Justin Drexler, on Flickr
ImageIMAG0644 by Justin Drexler, on Flickr
Radiator is sort of in. need some fastners and a couple of those rubber washers.
ImageIMAG0643 by Justin Drexler, on Flickr
ImageIMAG0642 by Justin Drexler, on Flickr
ImageIMAG0641 by Justin Drexler, on Flickr
ImageIMAG0640 by Justin Drexler, on Flickr
ImageIMAG0639 by Justin Drexler, on Flickr
Postby arranj » Mon Apr 17, 2017 9:24 pm
InoX wrote:Am I supposed to have four rad mounting rubber washers?
The parts manual says 4..... I have a feeling I may well have said "2" to you in an email or PM - quite possibly (not sure - sounds like the sort of thing I would do) - so please blame me! :confusion-seeingstars:
Just measuring pipe now for your peace of mind, but I see you are sorted?
Postby arranj » Mon Apr 17, 2017 9:30 pm
The pipe I have looks nothing like your pipe at all - which probably explains it then. This one is 2 inches longer than yours too.... It may well be that your header tank is mounted a bit higher than OEM too if it's a Hervey one.
What fixings do you need for the radiator install? The 2 bottom bolts, or something to attach the fans to the rad?
Postby InoX » Tue Apr 18, 2017 7:08 am
I just need two of the rubber washers plus two brackets/ clips to hold the hoses to the pontoon and inside rear bumper. I'll order them tonight. Think the pipe needs to come closer to the pontoon as when I mocked up the pipe to the water pump the hoses started to kink. Deffo need 4 rubber washers or else the rad isn't isolated from the frame. Cheers!
Postby mec » Wed Apr 19, 2017 9:00 am
where did you get your fans from ? they look like they bolt straight on ?
Postby InoX » Wed Apr 19, 2017 10:04 am
Toby and Misty. Delorean Parts North West.
https://www.delorean-parts.com/
yes, they did bolt straight on 8-)
Postby InoX » Wed Apr 19, 2017 1:46 pm
ImageIMAG0647 by Justin Drexler, on Flickr
centre bit re-leathered and installed on the console complete with mattaligner. Can't wait to install it in the car. If only I hadn't locked myself out. :? :oops: :doh: :think:
Postby MML » Wed Apr 19, 2017 10:14 pm
InoX wrote:ImageIMAG0647 by Justin Drexler, on Flickr
Where did you get the console pad recovered if you don't mind me asking? It looks great.
- Martin - VIN 5436 -
MML
VIN #: 5436
