Postby RobvdVeer » Wed Mar 04, 2015 8:47 pm
Admin-bloke wrote:Is that "spray foam"?
I think so. I found a shop but they charge quite the postage 2KG for €39+€12,50, so i'm still on the lookout.
Postby RobvdVeer » Thu Mar 05, 2015 4:52 pm
I found the 7th ht lead and all are installed now. After my fire extinguisher arrives i will continue on the fuel hoses.
Postby ALEXAKOS » Sun Mar 08, 2015 9:57 am
Nice going Rob! I had to remove the nice looking red alpine ht's cause apparently the Renaults have a different spark plug head and they don't grip onto the Delorean spec plugs.
Postby RobvdVeer » Sun Mar 08, 2015 10:38 am
Thanks!
Todays projects: fabricate a throttle link safety clip from a paperclip
Postby RobvdVeer » Sun Mar 08, 2015 3:18 pm
RobvdVeer wrote:Thanks!
Throttle link safety clip fabricated and installed.
Postby ALEXAKOS » Mon Mar 09, 2015 6:07 pm
May we have a visual on that ? ;)
Postby RobvdVeer » Mon Mar 09, 2015 6:09 pm
Of course. please allow me some time and photograph the situation tomorrow. I sprained my lower leg today. Walking to the garage again isn't a pleasure right now.
Postby RobvdVeer » Mon Mar 09, 2015 10:46 pm
Finally managed to order a $30 HID kit for the low beams, plus relays and connectors.
My headlights are already H4/H1 so other than the 12v line it is a screw and play kit basically. Another benefit is that i don't have to perform the headlight switch mod to save my switch from future damage :).
Nice job for the summer i think. It's Chinese so it may take a few weeks before it arrives. Can't be that bad, they sell the same junk in the high street here for over €150.
Postby ALEXAKOS » Tue Mar 10, 2015 10:02 am
I have installed such a set on my Delo. The only drawback on those cheap kits is that the ballasts are crap and it takes half a minute for the light to get its 100% beam strength. It's alright for night driving but as good as poop when you want to signal with the high beams.. I the daylight its invisible.
Postby RobvdVeer » Tue Mar 10, 2015 10:20 am
ALEXAKOS wrote:I have installed such a set on my Delo. The only drawback on those cheap kits is that the ballasts are crap and it takes half a minute for the light to get its 100% beam strength. It's alright for night driving but as good as poop when you want to signal with the high beams.. I the daylight its invisible.
I ordered just the one kit (for the low beams), because I hardly use the high beams anyway. Last time was 2001 I believe. And what do you mean by 'in the daylight it is invisible'. Did you get the 35W or the 55W kit?
