Page 3 of 40
PostPosted: Tue Mar 23, 2010 9:37 pm
by mnickels
Any how to's for removing the ball joints? Have this and removing the old bushes in the front control arms to do tomorrow. And the welder hasn't got back to me tonight :x
PostPosted: Wed Mar 24, 2010 3:36 pm
by mnickels
Welder coming on Saturday to do the work!!!!
I've been thinking today about fuelling this yoke. I have 3 twin Dell'Orto DRLA 40 carbs. Each needs a 3-3.5 PSI supply. I think I will need a pump, regulator and piping.
Ideally the pump will be halfway between the tank and the engine and below the tank level. It is my understanding that I will then need 2 T-pieces to get 3 supplies (1 for each carb). I am not fully confident on Carbs yet so am not sure on how well this will work.
Here is the pump I am considering http://www.fuelpumpsuk.com/12_volt_compact_fuel_pump.html
PostPosted: Wed Mar 24, 2010 3:49 pm
by A Van
What the guy use before to fuel all three carbs?
PostPosted: Wed Mar 24, 2010 5:12 pm
by mnickels
Not sure Al.
Not a lot more I can do without the frame done. Today I got the ball joints removed and painted and mounted the alternator. What a job that was, there was a bolt sheared in a mounting hole I needed. I then broke an easy out in it and eventually got it out with a cobalt drill bit.
So the welder is coming tomorrow night to make his shopping list for steel. He is going to repair my towing eye and rust damage as well as fitting reinforcement plates to my control arms.
I am on nightshift next week so all being well after sat I can leave it up to be galvanised and powdercoated.
PostPosted: Wed Mar 24, 2010 5:48 pm
by mnickels
Some pics
PostPosted: Wed Mar 24, 2010 6:16 pm
by bozzzydmc
mnickels wrote:removed and painted and mounted the alternator..
Eh up buddy
Just bear in mind the Alternator grounds through its mounting bracket so make sure you have bare metal to metal contact somewhere there
PostPosted: Wed Mar 24, 2010 6:18 pm
by mnickels
Eh up buddy
Bolts and brackets painted in situe so should be fine ;)
PostPosted: Wed Mar 24, 2010 6:22 pm
by arranj
wow! looks really good Matt. Will the engine cover actually close over those trumpets?
PostPosted: Wed Mar 24, 2010 6:27 pm
by mnickels
arranj wrote:wow! looks really good Matt. Will the engine cover actually close over those trumpets?
Don't know yet to be honest. I don't think it will so may need something fabricated as don't want to hack at the original. Looking at it the standard engine air box sits approx 4 inches above the air con compressor but mine probably sits another 8 inches.
PostPosted: Wed Mar 24, 2010 6:39 pm
by RobvdVeer
That looks superb Matt. I'm getting jealous now.
