Page 17 of 22
PostPosted: Sat Apr 18, 2015 10:35 pm
by MikeWard
Dan, those control arms look awesome!
PostPosted: Sun Apr 19, 2015 9:52 am
by Admin-bloke
I'd have a set, they look fantastic. I'd even open my wallet and pay for it too ;)
PostPosted: Sun Apr 19, 2015 10:34 am
by Biff
Do these arms actual bend under braking/cornering? And the plating stops this?
How about the upper control arms or are they reckoned to be strong enough?
Are we up-rating bushes aswell? Polyurethane ones?
PostPosted: Sun Apr 19, 2015 11:12 am
by bandit
Nice Dan, looks great
PostPosted: Sun Apr 19, 2015 8:51 pm
by Dan 6511
As the suspension goes up and down the arms try to twist because the anti roll-bar moves up and down in an arc. These plates stop the arms twisting but then the movement has to be taken up with the bushes. If you fit pollys in the anti rollbar AND where it attaches to the frame then your straining the whole setup a lot. I have kept rubber bushes in the arms where they attach to the frame. I had pollys in my old car and ended up swapping them back to rubber because the ride was so harsh and bangy and I found the pollys wore out very quickly from the stresses. The whole design is pretty poor really. It should have a lower arm similar to the upper arm, then the roll bar would attach with drop links.
PostPosted: Sun Apr 26, 2015 5:29 pm
by ALEXAKOS
Sweet Dan!!!! Yes the frame is a bitch to work on;)
PostPosted: Sun Apr 26, 2015 9:42 pm
by jamesrguk
Admin-bloke wrote:I'd have a set, they look fantastic. I'd even open my wallet and pay for it too ;)
+1 on that, I need to do a front end suspension overhaul this summer and boxing up the lower control arms sounds like a no brainier.
What's the easiest way of getting this done? Does anyone have a plan of the metal components required?
James
PostPosted: Sun Apr 26, 2015 11:35 pm
by Dan 6511
James, when I get some spare time I am going to draw up the plates so we can see about getting a load lazer cut :D
PostPosted: Mon Apr 27, 2015 6:34 pm
by delorean12uk
Dan 6511 wrote:I am thinking about modifying the front arms the same way that Jason Monk has done to his,
Got another picture for you Daniel
lower track control arm.jpg (1.7 MiB) Viewed 4283 times
I put a threaded plate on the inside of the chassis where the tank is to spread the load rather than nut and bolt it. All welding and fabrication done by me. Dan you said you changed back to OEM bushes on the front because you said the ride was less harsh??? I think mines improved with the poly bushes.
PostPosted: Mon Apr 27, 2015 6:49 pm
by Admin-bloke
That looks like a brilliant solution there Jay
