Posted: Sat Feb 24, 2018 2:05 pm
Cam confusion settled, the dmc and Volvo cams are identical. I somehow thought the dmc had a B27F...
This means I have a set of good cams and rocker assembly, and it also means more work. The good news is that I’ve figured out a way to replace cams and the rocker assembly without undoing the head bolts.
I’ve practiced on my broken Volvo engine.
The timing cover is off the B28E, and one chain tensioner is loose. The oil pump chain is also very loose .
