Posted: Tue Mar 20, 2018 10:09 pm
Small steps while I wait for a replacement camshaft.
The DeLorean Club UK forum for European DeLorean owners and enthusiasts.
http://www.deloreaneurotec.uk/
Admin-bloke wrote:Did you change the crank seal behind the flywheel? They are prone to leaking. There's a multi ribbed version (for your pleasure) that's a modified one to help stop it leaking out
Admin-bloke wrote:If you do decide to get new cams or redoing ones, make sure you RUN the cam in correct ie not let the car just idle on startup.
Edit: RUN the cam in, not need
