Hi all
A small update for you, the chassis as you know is now at Alex's, he has it all set up and has started work ...
- IMG-20181028-WA0012 (Medium).jpg (175.7 KiB) Viewed 2538 times
- IMG-20181028-WA0013 (Medium).jpg (171.21 KiB) Viewed 2538 times
- IMG-20181028-WA0014 (Medium).jpg (140.14 KiB) Viewed 2538 times
As you can see all of the repair areas have been marked up no matter how big or small, the total is around 70 repairs !
the following pics are the 1st area that has been started, this is under the rear dog bone section (now removed), poor previous repairs have caused a lot of the problems on my chassis, so these are all being removed and done properly.
- IMG-20181028-WA0006 (Medium).jpg (209.43 KiB) Viewed 2538 times
- IMG-20181028-WA0005 (Medium).jpg (172.43 KiB) Viewed 2538 times
- IMG-20181028-WA0004 (Medium).jpg (205.36 KiB) Viewed 2538 times
hopefully more updates from Alex to come over the weekend
I have also been doing a bit of work in the garage, i now have the front wheel bearings removed from the front hubs and also driveshafts disassembled, these are a bit worse for ware, with not a lot of grease in them..
- 20181101_122457 (Medium).jpg (212.35 KiB) Viewed 2538 times
- 20181101_122505 (Medium).jpg (190.35 KiB) Viewed 2538 times
So now i have another batch of stuff to go to the blasters/coaters..
- 20181102_124021 (Medium).jpg (276.08 KiB) Viewed 2538 times
That's all for now folk's
