Page 10 of 35
Re: VIN 5219
PostPosted: Fri Jun 21, 2019 1:19 pm
by bandit
I bought one of those Gunston pressure bleeders. Dead cheap & work mint, you just connect it to you tyre valve & can do it on your own easy
Re: VIN 5219
PostPosted: Fri Jun 21, 2019 1:52 pm
by DMC1983
mec wrote:I did all mine on the car, just put the fluid in and start pumping the pedal, mine was a completly empty system, it didnt take long at all
Mine too is completely empty. Did you do this on your own? And did you use more than 1ltr of dot4?
bandit wrote:I bought one of those Gunston pressure bleeders. Dead cheap & work mint, you just connect it to you tyre valve & can do it on your own easy
Ive got a buddy to help me. Not having a job currently i want to try and minimize spending where i can. But thanks for the tip :)
Re: VIN 5219
PostPosted: Fri Jun 21, 2019 3:26 pm
by andyd
I seem to remember that none of the dummy caps supplied with the Gunson kit fitted the D?
I also ended up doing it the 2 man way.
Given the work done, new hoses etc I would keep a careful eye for leaks at the new unions under pressure.
Re: VIN 5219
PostPosted: Fri Jun 21, 2019 5:30 pm
by DMC1983
Will do. I did the same when i changed the fuel lines, accumulator, filter and pump.
Re: VIN 5219
PostPosted: Fri Jun 21, 2019 9:04 pm
by mec
Yea the gunson pressure kit leaked liked crazy for me, yea i used probably 2 litres of fluid :thumbsup:
Re: VIN 5219
PostPosted: Sat Jun 22, 2019 10:18 am
by bandit
Fitted mine, don’t recall doing any mods on it
Re: VIN 5219
PostPosted: Sun Jun 23, 2019 8:00 pm
by DMC1983
Brakes have now been bled and golly gosh they work lovely. Yay! Gotta be careful till the pads are worn in.
The handbrake, what a POS that is. Ive got it now so pretty much the full pad touches the disc. I cant roll the car on the drive but will it be good enough to pass the MOT, we will see. I had to file down 1 pad on each side (the inner ones) and adjust the cable on one side. I can now honestly say i am a master at removing the handbrake and reattaching it.
So all thats left now is the fog light. Im about to start a new job tomorrow so its looking like i wont get round to that till next weekend. I may find some time during the week but doesnt matter as I wont put the car through an MOT till the first pay day anyway.
So the car will be attending the october meetup as long as it stays running :D
Re: VIN 5219
PostPosted: Sun Jun 23, 2019 9:10 pm
by Admin-bloke
Congratulations on getting another job so quick :D
Re: VIN 5219
PostPosted: Sun Jun 23, 2019 9:41 pm
by DMC1983
Thanks. What can i say? Im a catch :lol:
Re: VIN 5219
PostPosted: Mon Jun 24, 2019 9:47 am
by mec
Top work :thumbsup:
