Posted: Thu May 18, 2017 8:01 pm
According to the manual, Fuse 11 protects:
Radio
Clock
Gear selector lamp
A/C Panel lamps
Electric Windows
Try disconnecting both window switches and see if the fuse has not blown.
If it hasn't, then connect one of the original window switches and check operation of the window. If this is OK then try a new window switch in the same socket to operate the same window, with note to any specific orientation to the socket and wiring colours. If the fuse blows then suspect the new switch.
Good luck
Radio
Clock
Gear selector lamp
A/C Panel lamps
Electric Windows
Good luck
