Page 48 of 57
PostPosted: Sat Sep 29, 2018 4:17 pm
by Domi
A few news from today, I just lift the car on jacks
For now it is 40 cm away from the ground, I don't know if it will be enough to get out the gear box on my little cart...
PostPosted: Sun Sep 30, 2018 9:00 pm
by andyd
Probably ok Domi?
I had wheels, driveshafts, brakes and shocks off when I had my box out, which may have been easier...
Good luck! The box doesnt sit perfectly on the jack, and thd engine will tilt when you remove the box, so you need to re-level it with another jack to get the box back in. But thats a little way down the road. Glad you ard able to start working on it again!
PostPosted: Sun Sep 30, 2018 9:51 pm
by Domi
Thanks for the advice for the engine, I'll try to remember when I will put the box back in ;)
PostPosted: Sat Oct 06, 2018 6:10 pm
by Domi
First of all, I'm going to replace my pipes and get back to the original after a good cleaning
PostPosted: Mon Oct 08, 2018 2:48 pm
by cis6409
Tedious job but will be well worth it in the end.. Amazing the dirt that gets baked on to them pipes!
PostPosted: Mon Oct 08, 2018 5:27 pm
by Domi
Yes, they will be nicer after a good cleaning (I hope so)
PostPosted: Sun Oct 14, 2018 8:30 pm
by Domi
Today I have finished of dismantling the old pipes to get back to the original ones which solved my steering problem.
Still four left pipes to mount and the job will be done, just flush of liquid.
PostPosted: Sun Oct 21, 2018 4:55 pm
by Domi
All pipes are now back in the car, just need to put some water in the tank and it will be fine
Next step, the gear box…
If I see correctly, there is only 4 rear bolt to remove?
Apparently, 2 more for the starter?
And for the bracket, screw number 1 or number 2?
And of course the manual shifting
PostPosted: Sat May 18, 2019 6:36 pm
by Domi
Can't do the job alone, so the car is going to a mechanic...
PostPosted: Mon May 20, 2019 3:17 pm
by cis6409
Sometimes it comes to that domi, but hopefully it ll be sorted in no time... With a mechanic and lift it should be sooo much easier
Best of luck with it!
