Page 1 of 3
RPM Relay Socket
PostPosted: Wed Aug 11, 2010 7:53 pm
by RobvdVeer
PO removed the socket, now its just loose wires and spades. Does anybody know a brand/model replacement part? So such parts listed on normal vendor sites.
Re: RPM Relay Socket
PostPosted: Wed Aug 11, 2010 7:57 pm
by Admin-bloke
You can ask Dan and Gez and see if they can snip off the socket (and leaving some cable on it) from the car they are taking the engine out of........
by Dan 6511
How about a plug cut off another loom, you could solder/heatshrink the wires onto your loom...?
PostPosted: Wed Aug 11, 2010 8:18 pm
by RobvdVeer
Dan 6457 wrote:How about a plug cut off another loom, you could solder/heatshrink the wires onto your loom...?
Brilliant. My search just went from a single socket to a single socket and a loom. :(
PostPosted: Wed Aug 11, 2010 8:28 pm
by Dan 6511
We can probably cut one off the Volvo we are ripping the engine from.
PostPosted: Wed Aug 11, 2010 8:42 pm
by RobvdVeer
Smashing!
Its probably only a 0.20€ part so it should be available somewhere. Let me give EdU a ring too.
PostPosted: Thu Aug 12, 2010 6:06 pm
by RobvdVeer
Could this be it?
http://www.rdae.nl/multistekkers/multico...ts_id/1266
or
http://www.rdae.nl/multistekkers/multic ... ts_id/1202
Categorized as 6.3mm connectors. 2x3.
Edit: www.rdae.nl also stocks those hard-to-find bosch connectors to the WUR/CSV etc.
PostPosted: Thu Aug 12, 2010 6:55 pm
by Admin-bloke
Looks like the one.
The blade connectors are definately 6.3mm :)
Does this include the blade connectors themselves or is it ust the socket?
PostPosted: Thu Aug 12, 2010 7:02 pm
by RobvdVeer
The site sells different variations/combinations of the sockets. Male, Female, with/without pins.. There's a complete set for €2.00 i'll be checking it out. To save on P&P i'll put together a list of may-need items.
PostPosted: Thu Aug 12, 2010 7:34 pm
by bozzzydmc
Rob are the spades on the relay wires the type with the little 'tang' on ? If so then these will just push back into your new socket ...
