Page 1 of 2
replacement rear wheel bearing
PostPosted: Sun Jul 28, 2013 5:52 pm
by marwood82
hi,
i need to replace one of my rear wheel bearings asap.
has anyone used the crossreferenced part on here? (QWB213)
http://www.deloreaneurotec.co.uk/forum/viewtopic.php?f=28&t=2217
do they fit ok?
are there any others that people have used that would be available on the high street?
(as i said, i need to get it replaced quickly so would ideally like something i can go to an car parts store and buy)
If i understand correctly, these here then will also fit?
http://www.autopartoo.com/oe/alloelist.aspx?ue=QWB213
thanks
Simon.
Re: replacement rear wheel bearing
PostPosted: Sun Jul 28, 2013 8:09 pm
by arranj
Hi Simon - as you know we have them in stock: viewtopic.php?t=2486 - I have PMd you with a link to get them to you by 1pm on Tuesday guaranteed. Can also do "by 9am guaranteed" for about treble the postage price... No idea about the cross references from different manufacturers, but those part numbers should be correct!
PostPosted: Sun Jul 28, 2013 10:25 pm
by A Van
If you have one gone, the other will follow, I would do both if you can
PostPosted: Mon Jul 29, 2013 10:02 am
by arranj
on their way to you now Simon - will be there tomorrow. :)
PostPosted: Mon Jul 29, 2013 4:14 pm
by marwood82
thanks for that!
had it looked at this morning, drivers side rear bearing needs replacing and the passengers side one is starting to go.
also, it seems my front discs need changing, so its a good excuse to get all 4 bearings changed
PostPosted: Mon Jul 29, 2013 4:25 pm
by arranj
Where are you getting your front discs from? I assume not from the UK?
PostPosted: Mon Jul 29, 2013 5:55 pm
by marwood82
arranj wrote:Where are you getting your front discs from? I assume not from the UK?
my local car parts store is ordering them from here. they should get them in the morning
http://catalogue.brake-eng.com/index.ph ... t=DI955013
i picked up the cortina brake pads from halfords that are on the crossover parts list.
what do you guys think, is it really worth changing the front bearings if they arent bad? or am i best to leave them?
PostPosted: Mon Jul 29, 2013 6:41 pm
by A Van
Hi mate
I changed both front wheel bearings in May 2011 after Eurofest
Al
PostPosted: Mon Jul 29, 2013 6:44 pm
by marwood82
A Van wrote:Hi mate
Al
ok. if they're still ok i'll probably leave them then.
PostPosted: Mon Jul 29, 2013 6:55 pm
by A Van
Can't see why they won't be ok, only a couple years use
I changed them as they became noisy... Probably after the thrashing it got at the Autotest event!
