Page 1 of 1
Wanted 106982 Fir Tree Connector
PostPosted: Mon Mar 10, 2014 9:34 am
by conor
Really stuck for one of these; 106982 Fir Tree Connector.
http://www.delorean.eu/catalog/product_ ... s_id=48001
Send me a PM if you have one for sale.
Thanks,
Conor
Re: Wanted 106982 Fir Tree Connector
PostPosted: Tue Mar 11, 2014 10:50 pm
by jamesrguk
conor wrote:Really stuck for one of these; 106982 Fir Tree Connector.
Thanks,
Conor
1st off I've never heard them called that before which is why you may have had trouble tracking them down to buy. A search for 'brass barb uk' throws up several uk retailers.
I actually have some knocking around you can have for the cost of postage, where are you?
But you can pick them up quite easily from Halfords and others if I recall correctly
James
PostPosted: Tue Mar 11, 2014 11:26 pm
by andyd
Hi Conor,
Sorry I never clicked the link. I presumed you meant interior ones... :roll:
I had a problem with this (tho maybe it wasn't necessary, going by James's reply !!)
I bought the stainless return line from DMCH. I then realised I needed the "fir tree" to go onto the bush. I got this part from Ed. I expected them to be the same thread. (well, its not unreasonable, is it??)
No joy....
I googled the name on the nut supplied with the DMCH line. I could get a fitting, but no, they couldn't supply a hose barb to mate to it. I was a bit wary as this really needs to seal fuel at a reasonably high pressure. Maybe I was being over-cautious (I wanted a guarentee that the parts I fitted would seal!)
In the end, I used the stainless hard line, ditched the nut, and ordered:
AN -6 (AN6) STRAIGHT Male To 5/16" (8mm) Tube Adapter
and
AN -6 (AN6) STRAIGHT to 8mm 5/16" Barb Hose Fitting
from torques.co.uk
Links-->
http://www.ebay.co.uk/itm/6-AN6-STRAIGH ... 27bb766698
and
http://www.ebay.co.uk/itm/6-AN6-STRAIGH ... 27c83c581b
Not that cheap, but I got a pressure- and fuel- rated solution which connected my hard line to the flexi hose.
a
PostPosted: Tue Mar 11, 2014 11:31 pm
by andyd
Oh, and yes, if you want this part (is Ed out of stock??) I still have Ed's part spare.
However, if you're in a rush then no luck, as I wont be back at the car till about mid April...
If you can wait then I'll post it over, but suspect you may get one before then!! Sorry bout that, good luck!
a
