Page 1 of 2
Engine Block Desperatly Needed
PostPosted: Sat Jan 30, 2016 3:52 pm
by Dan 6511
I know this is a long shot as they are like rocking horse shit these days, but does anyone know of an engine block that is available and not rotten?
I have just snapped off a head bolt on mine, gutted. :(
Re: Engine Block Desperatly Needed
PostPosted: Sat Jan 30, 2016 5:48 pm
by Admin-bloke
Is it just the bolt that had snapped or the block?
PostPosted: Sat Jan 30, 2016 7:22 pm
by jerzybondov
Which one did you snap the bolt off from? The original D block?
PostPosted: Sat Jan 30, 2016 8:08 pm
by Dan 6511
Head bolt snapped and left end in the block. On my original delorean block. My volvo block is rotten but all the bolts came out fine, typical!
Alistair recons he knows a place that can extract it, and i've found another machine shop up north that can spark erode it so all is not lost just yet.
PostPosted: Sat Jan 30, 2016 9:11 pm
by jerzybondov
Yeah I'd have fancied your chances of getting that out. What happens with the thread after though? Do you need a special new bolt and tap out a special new thread in the block?
PostPosted: Sat Jan 30, 2016 9:42 pm
by Admin-bloke
Dan 6511 wrote:Head bolt snapped and left end in the block. On my original delorean block. My volvo block is rotten but all the bolts came out fine, typical!
This place near me that's been going for 40 plus years does spark erosion:
http://www.locksideengineering.com/services.php
They did my cylinder head work on my old astra diesel and disc skims etc.
Just say the engine is from a Volvo ;)
Mind you, up North to you may be well 'Down South' to me, all relative. ..
PostPosted: Sat Jan 30, 2016 10:29 pm
by Dan 6511
Cheers for the link Nick. Do you know how spark erosion works? What stops it eating the aluminium as well as the steel bolt?
PostPosted: Sat Jan 30, 2016 10:45 pm
by Admin-bloke
Dan 6511 wrote:Cheers for the link Nick. Do you know how spark erosion works? What stops it eating the aluminium as well as the steel bolt?
http://www.sparkeroding.co.uk/process.htm
The Knowltons will have far better knowledge than I ever would on engineering things like this :D
PostPosted: Sat Jan 30, 2016 10:53 pm
by jamesrguk
I looked at spark eroding for a completely unrelated project a few years back.
Effectively spark erosion is just a very high temperature electrical pulse which is very acurately shot into the material you want to remove, at the same time coolant is added. the rapid heating (several thousand degrees c) and cooling effect causes the offending article to shatter and turn to dust, but it is very precise so the huge heat does not effect surrounding material.
That said you would still need to retap the hole and unless I'm mistaken spark eroding / electrode milling, is pretty expensive.
J
PostPosted: Sun Jan 31, 2016 9:50 am
by DJK73
Hi Dan
I would get it soaking in plus gas straight away as this will help who ever extracts it
Then I would go down the route of extraction rather than spark eroding as that is normally a last resort or for removing broken taps or drill bits etc and it's expensive
A decent machine shop should be able to set that up in a milling machine and drill out the centre of the bolt, this will relieve the pressure on the thread. Then remove it with an "easy out" and some gentle heat. Should save the thread.
Hope that helps
Dan
