Rear hub wanted
Hello,
I'm in need for rear hub as mine has damaged splines.
I only need part of hub with studs, important part are splines - they need to be in very good condition.
Photo for reference :
If you look carefully, left one has damaged splines, right one is perfect. I'm looking for one like the one on the right. They can be corroded, not a problem.
