Sunday Times Review
Re: Sunday Times Review
Postby DeLorean Cars » Mon Feb 22, 2010 7:06 pm
delorean12uk wrote:
When Jay Leno started it up the engine was hunting, was that a standard feature of the car??? you mean I've just spent the last 17 years trying to erradicate a feature that was meant to be there???
When cold, that's quite normal - I set them up like that but there're other schools of thaught.
DeLorean Cars
VIN #: 4772, 3352
Postby Dan 6511 » Mon Feb 22, 2010 7:15 pm
DeLorean Cars wrote:When cold, that's quite normal - I set them up like that but there're other schools of thaught.
My volvo never hunted at all when cold or hot.
Postby DeLorean Cars » Mon Feb 22, 2010 7:17 pm
Your Volvo doesn't have a lambda system.
DeLorean Cars
VIN #: 4772, 3352
Postby Dan 6511 » Mon Feb 22, 2010 7:20 pm
Oooh I see. So really the lambda systems starves the engine of power and makes it idle like a pile of crap!!
Postby delorean12uk » Mon Feb 22, 2010 10:05 pm
Dan 6457 wrote:Oooh I see. So really the lambda systems starves the engine of power and makes it idle like a pile of crap!!
Daniel!!! it was a unique design feature that Delorean tried to incorperate into every car that would lead the new owner into believeing the car had a personality, a bit like Herbie!!! thats why my one is called C@#t car, mine hunts, don't starts, then starts when you unlock the doors, loses 3rd gear, wipers don't park, rev counter eratic, just to name a few little unique features that makes my car shit.............I mean mine. I love it!!!
Postby Admin-bloke » Tue Feb 23, 2010 10:38 am
Hunting is too rich a mixture setup usually coupled with idle speed control valve not giving a fast idle (volvo would probably use an auxiliary air valve anyway).
The hunting can be adjusted out with the brass screws to reduce the proportionate gain of the movement of the idle speed control valve due to the slow reactance of the idle ecu and i obtained a fast idle by adding a 10k ohm resistor in series with the coolant temp sensor....oh and I also set the fuel mixture to spec.
Postby delorean12uk » Tue Feb 23, 2010 4:46 pm
Admin-bloke wrote:Hunting is too rich a mixture setup usually coupled with idle speed control valve not giving a fast idle (volvo would probably use an auxiliary air valve anyway).
If liverpudlian chav man was selling this car as new, surely this must have been sorted out
