Fuel Lines / Stainless Fuel Hoses - £219.99
Stainless steel lettering and engine cover grilles, in stock and shipped from the UK
Re: Fuel Lines
Postby RobvdVeer » Sat Aug 21, 2010 8:14 pm
RobvdVeer wrote:If these are what Arran said (3 hoses from the fuel pump to the hard lines) i am interested too. This season my lines lost all their rubber mantles and need to be replaced.
Just a quick note to let you know I've replaced the hoses at the fuel pump side today with some help from our friend Welmoed, so I don't need these anymore.
Re: Fuel Lines
Postby delorean12uk » Tue Aug 24, 2010 10:05 am
bandit wrote:If anyone is interested in the fuel lines made in braided stainless, from the metering head, I could have these done no problem & they would be at a decent price.
If there is any interest, let me know. Also if anyone has a spare set, even if they are no good, just to use as a pattern that would be great.
Jules
Mr bandit Bender, I would be interested?? would you require an old OEM set for the fittings and how much would we be looking at????
Re: Fuel Lines
Postby arranj » Tue Aug 24, 2010 10:47 am
Answering on Julian's behalf, because I was there. He has got 10 fuel lines from Admin-bloke ready to be sent off to be copied. However it would appear he is missing 3 - I think there are 13 in total on that side?
Plus 3 more on the fuel tank side too - he hasn't got those to template either. What have you got Jason?
In terms of price, something in the region of £10-£13-ish per hose on average, or that sort of ballpark, but don't quote me! ;)
Re: Fuel Lines
Postby delorean12uk » Tue Aug 24, 2010 11:56 am
6 hoses from the metering head to the injectors, 2 hoses 'to and from' the control pressure regulator, 1 hose to the cold start injector, thats 9, what else is their????
Re: Fuel Lines
Postby arranj » Tue Aug 24, 2010 12:19 pm
2 hoses to and from the frequency valve
Supply hose from fuel filter
Return hose/fuel line (from the tank) - engine bay side
Plus of course the 3 hoses tank-side
Postby Chriss » Tue Aug 24, 2010 12:32 pm
I should have a complete engine set, not counting feed to metering head, you can borrow if needed. They are used but ok, the fuel return is brand new!
Re: Fuel Lines
Postby RobvdVeer » Tue Aug 24, 2010 12:40 pm
Question: where is the line to the accumulator?
As a side question: is there any picture from the full underside of the car with all the panels removed, so there is a proper view of all the lines and hoses? Should be taken from under a bridge i suppose
Re: Fuel Lines
Postby arranj » Tue Aug 24, 2010 12:50 pm
There are two lines to the accumulator no? One of them is one of the 3 106979 hoses mentioned above (the fuel tank side) - the other one is 106997 and doesn't get a mention :(
http://www.delorean.com/store/c-274-2-1 ... oretc.aspx
Re: Fuel Lines
Postby bandit » Tue Aug 24, 2010 2:42 pm
Yeh, if the others are available from someone, it would make sense to do them all at once
Re: Fuel Lines
Postby tourettes tony » Wed Aug 25, 2010 8:30 pm
heres my set 6 years on
fuel lines (Medium).jpg (73.71 KiB) Viewed 6997 times
Return to Just Bandits
