very nice engine indeed
the Lancia PRV has the same engine block of the delorean, same liners, still odd-firing with kjet but pistons with 9.5:1 compression... and should be better cams, but i dont have numbers for them.
The heads are for k-jet, but they are not the same delorean one: they are the improved design with the oil bath for the cams: the cast number is the same of the 2.5lt turbo PRVs heads, but with kjet holes opened. Different cams followers also, still mecanical, but like the late renault r25 prvs.
wich need to fit the delorean valve covers a machining on them inside.
This engine will have soon an english exhaust
and i will be very curious to see how it l run...should be very good
other photo of this job here
http://picasaweb.google.it/cinemanvero/VIN4528#
