Postby RobvdVeer » Sat Jan 22, 2011 5:39 pm
Come to think of it, I might need a gasket/o-ring/copper washer kit before reassembly. What standard kits are available?
Postby arranj » Sat Jan 22, 2011 5:49 pm
The one we sell here: viewtopic.php?f=66&t=382 (back in stock soon!)
is this one: http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0457060814 - £67.50 sent to you.
For the money you can't beat it really! Cheaper than 253 Euros!: http://www.delorean.eu/catalog/product_ ... s_id=33003
Postby RobvdVeer » Mon Jan 24, 2011 8:19 pm
Gotta question for you lot.
I am doing the VOD bit, and it looks quite ok. Yes the old paint job has dissolved but otherwise it was clean and solid except for a bit of old coolant mucking in there. No oils whatever. I've cleaned the bit up, but i haven't removed the Y-pipe yet because I am scared of breaking things like bolts that are ok.
Would it be ok just to clean it up and spray in a bit of tectyl to seal it up before reassembly?
Postby RobvdVeer » Fri Jan 28, 2011 5:41 pm
LOL I love this new technology!
Postby arranj » Fri Jan 28, 2011 5:45 pm
Yep, that worked! :thumbsup:
Postby RobvdVeer » Sat Jan 29, 2011 11:58 am
Just a verification check, this is the CSV pipe connection to the intake manifold:
#8 is a copper washer
#9 is a rubber o-ring
Just want to be sure because all other fuel-related lines have 2 (two) copper washers.
Postby tourettes tony » Sat Jan 29, 2011 12:00 pm
bottom one is an o-ring ( although the engine i picked up has a flat rubber washer ) top copper TT
Postby RobvdVeer » Sat Jan 29, 2011 12:04 pm
Thanks.. I found that o-ring on the floor (fell of the intake) and now i know what it's for. As a good habit I clean the floor before any job and check for items when done.
Dont want to start the car in a couple of weeks with my hand filled with a bunch of surplus bolts left.
Postby RobvdVeer » Sat Jan 29, 2011 3:49 pm
More progress made. Today I removed the final bits of piping in the VOD without any issues. Bolts from the Y-pipe came out without any struggle whatsoever. Woohoo! No broken bolts! (I was scared about this quite a bit). Now that everything is loose I can start cleaning up.
Postby Admin-bloke » Sat Jan 29, 2011 7:16 pm
Nice one Rob.
Get that valley cleaned out and painted. I used cylinder black for air cooled bike engines.
Delorean Engine Stripdown 004.JPG (824.68 KiB) Viewed 3517 times
