Postby RobvdVeer » Thu Aug 04, 2011 5:30 pm
Woohoo, i've installed Dave McKeen's new Dome Delay module, and it works! :thumbsup: (not the first time though, doesn't work with neon inverters)
Postby RobvdVeer » Fri Aug 05, 2011 11:47 am
Parts came in! Christmas surely has come early this year!
Postby RobvdVeer » Wed Aug 10, 2011 9:08 pm
Footwell lighting and LCA support brackets installed. Ball joints and bushing set aside for winter maintenance. I might need to tackle the rear suspension by then.. I wonder if it will ever be finished! :mrgreen:
Postby RobvdVeer » Mon Aug 15, 2011 7:54 pm
Yesterday I took the D for a spin to check out the LCA supports. The difference under braking and cornering is amazing.
But I seriously need to take them out again to fix the instability with the other bits. I need to change the regular LCA bushings and the lower ball joint on the LH side. Check tyre pressure, and possible a realign on the front. Parts are in-da-house, just need to find time to install.
Postby RobvdVeer » Thu Aug 18, 2011 4:26 pm
The weather is just effin' brilliant (borrowed that term). Might be a good time to get a head-start on the winter jobs this weekend...
Also, my subwoofer order got delayed because of back-orders.
Postby RobvdVeer » Sat Aug 27, 2011 7:52 pm
In my attempts to do useless things today, I tried to fasten my passenger seat adjustment knob. But I could not get it loose. there seems to be a plastic panel inside the thing. I tried putting a screwdriver in but this ended in a scratched part.
How does one get the adjuster removed without damage?
Postby Dan 6511 » Sun Aug 28, 2011 1:39 am
I seem to remember having to use a suction cup to pull out the cover, then you can get to the nut behind it.
Postby RobvdVeer » Sun Aug 28, 2011 9:18 am
Dan 6457 wrote:I seem to remember having to use a suction cup to pull out the cover, then you can get to the nut behind it.
Thanks, (starts looking for a suction cup)
Postby RobvdVeer » Fri Sep 09, 2011 7:01 pm
Tried to finish up the front suspension. Hard luck. Two of the locking nuts I used to double up for the torsion bar bolts slipped from my fingers into beam of the frame (inside the crumple zones). And with no spares, and the shops closed, i will have to wait until tomorrow to fix it.
Note to self: Learn to do helicoils or welding.
Postby Dan 6511 » Fri Sep 09, 2011 8:48 pm
When I did mine Rob I managed to get the lower arms on and off without removing the roll bar, because like you I have nuts inside the frame rather than relying on the frame threads.
