SOLD Parts Car on Ebay
Postby A Van » Sun Dec 04, 2011 12:31 am
What was the record Jez?
If memory serves it was a somewhat short lived record
Re: SOLD Parts Car on Ebay
Postby jerzybondov » Sun Dec 04, 2011 11:35 pm
A Van wrote:What was the record Jez?
Was 139bhp I think but that was on the previous dyno we used where the readings were lower for everyone.
Postby Admin-bloke » Mon Dec 05, 2011 1:07 pm
Aaaagh, I remember that well ! From flat-bed to highest bhp !!
Postby bozzzydmc » Mon Dec 05, 2011 1:50 pm
Gez, im confused as to why you then swapped your engine out, was it for the new cams ?
Postby Dan 6511 » Mon Dec 05, 2011 4:01 pm
Becuase I beat him at santa pod ;)
Postby jerzybondov » Mon Dec 05, 2011 4:14 pm
bozzzydmc wrote:Gez, im confused as to why you then swapped your engine out, was it for the new cams ?
Well I'd bought the Volvo engine as it seemed like to good an opportunity not to - and I thought if I put the cams in it too it would be a worthy swap. Whether it has been or not is of course open to debate :)
Have decided that there a two things left to do in the HCs saga - firstly try a different emissions machine - the one I've been using that tells me I'm up at 4000 is different to the one I previously had readings of 700 on. So could perhaps be more sensitive/differently calibrated.
And I've also found a local classic car mechanic who has a proper smoke machine so going to get it tested properly for vacuum leaks. Once that's done I should be in a better position to actually pass the next MOT! (and of course have the satisfaction that the car is running as it should)
Postby Manxmann » Mon Dec 05, 2011 6:18 pm
jerzybondov wrote:(and of course have the satisfaction that the car is running as it should)
What like a coffin on wheels, sorry I mean a Volvo 760? :lol:
The Manx 'D' - VIN 17152
Manxmann
VIN #: 17152
