Vin 11766 Middle Eastern Car
Re: Vin 11766 Middle Eastern Car (Mine this time!)
Postby Dan 6511 » Sun Oct 25, 2009 8:52 pm
Nice one Al! It looks pretty good underneath now. Are those John herveys lower balljoints? You will have to take me for a ride in it sometime so I can see how the ride differs to mine.
Postby arranj » Wed Oct 28, 2009 1:22 am
Al - it's just occured to me. If the chassis Dave Howarth has for sale here: viewtopic.php?f=35&t=201 - is listed as being "just for an auto" - what modifications have you had to make to your car to make the chassis suit a manual? :?
Postby dmc4087 » Wed Oct 28, 2009 10:16 am
You need to make modifications for the manual shifter, and drill a hole for the crossgate cable - the gearbox mounts are different too. I think thats it though
Postby DeLorean Cars » Wed Oct 28, 2009 11:19 am
The only modification is to drill a hole for the crossgate cable
The only custom part is the bracket to hold the manual shifter to the auto mounts (lower & different)
Everything else is just a case of finding the original parts, many of which are no longer avialable - gearbox mounts being one of them. The rubber mounts that attach to the chassis are the same manual and auto.
DeLorean Cars
VIN #: 4772, 3352
Postby A Van » Thu Oct 29, 2009 11:25 am
The modification to the chassis is much easier to perform with a frame off!, Chris N had already made two templates to raise the shifter before on other cars, so all ok there.
I was very lucky with some of the impossible to get parts, and saved over 330 dollars by looking around and emailing whoever I could think of that might have some bits, then I was also lucky that Dan offered to bring the bits back from Vegas for me (as did Messrs Spratt and Monk, if Dan had run out of room), and also MNickels for a great price on the gearbox itself!
Postby dmc4087 » Thu Oct 29, 2009 12:11 pm
I was quite lucky too, got my bits from Josh Haldeman - I think they were from a burnt out car
Postby Admin-bloke » Thu May 20, 2010 1:24 pm
Al, I thought I would show you a pic of your central locking pre-repair.
Shows the replacement relay (experimental and blagged for free from a supplier)
Shows an oem coil (purple) against my rewound copper enamelled thicker wire.
The central locking is now fully working
1 solenoid is now fully working
The second pic shows the burnt out solenoid.
This spool shattered when unwinding it heat build up in it.
As soon as you send me another couple of duff ones I will make as many good ones as I can with the parts.
Enjoy :D
als central locking pre repair showing new relay to be fitted.jpg (19.99 KiB) Viewed 8333 times
burnt solenoid.jpg (21.9 KiB) Viewed 8333 times
Postby A Van » Fri May 21, 2010 10:33 am
Looks good Admin, reaping!!
I will see if I can get hold of another duff one.
Postby A Van » Sun Dec 11, 2011 4:30 pm
I have sold my car today to a fellow club member who is driving back to Birmingham in it now,I am sure he will chime in later!
Postby RobvdVeer » Sun Dec 11, 2011 4:33 pm
I can imagine the standard new-owner-question-list:
- doors are hangin' down
- too bad there's no real flux capacitor
- where do i go for a new windscreen
- when driving on the highway @156Mph, the rear end broke out, anybody has a spare fender?
:D
no but seriously, i am sorry to hear you've sold it. I do hope you keep hang'a'bout.
Return to Middle Eastern Cars
