Postby tourettes tony » Sun Aug 23, 2009 9:48 am
Looks ok to me Rob best you bring her over next june TT :D
Postby RobvdVeer » Sun Aug 23, 2009 10:06 am
What do you think of the custom exhaust job? The picture shows only the lower muffler, but there is a second one on top of that going the other way. Left 3 cylinders are not connected to the right ones. (Just cross your arms to known what i mean).
Also on the pictures you see them new Kumho KH15 tires.
Postby tourettes tony » Sun Aug 23, 2009 10:10 am
looks good to me rob, tyres in my opinion not too critical as long as they are branded TT
Postby arranj » Sun Aug 23, 2009 12:34 pm
Hi Rob
Do you mean there are TWO back boxes? i.e. another one above this picture? :?
Postby RobvdVeer » Sun Aug 23, 2009 2:49 pm
Yes, Arran, there are 2 mufflers (you can only see 1 round one on the picture).
I've attached a picture that shows the mufflers from the lower right side for clarification
Postby RobvdVeer » Sun Aug 23, 2009 3:14 pm
Dan 6457 wrote:I like those wiper blades. What are they from?
Here is some pictures from the packaging
Delorean bijna klaar 031.JPG (152.27 KiB) Viewed 5775 times
Delorean bijna klaar 030.JPG (101.97 KiB) Viewed 5775 times
Postby jamesrguk » Fri Aug 28, 2009 11:38 pm
They use those wipers on most new VW passats golfs etc... they are pretty good and supposidly spread the force on the windcreen a little better than the traditional style.
J
Postby RobvdVeer » Thu Sep 10, 2009 8:23 pm
Only 12 hours till MOT. I feel ready. Crossing the fingers here..
Postby tourettes tony » Thu Sep 10, 2009 8:40 pm
good luck mate tt
Postby RobvdVeer » Fri Sep 11, 2009 11:21 am
Just got back from MOT. I failed.
- CO was a little too high. That was probably because the car sat still too long. Easily fixed by driving more and adding a cleaner fluid to the fuel.
- I seem to have too much break lights. This never was a problem. Also easily fixed by removing some bulbs
- I do need new balljoint jackets (translated from fuseekogelhoesjes) in the front, 4 pieces (2 up/2 down). These are practically worn out and need to be replaced
That's all! No rust, no leakage. Pretty good actually for a car that was stored for more than 4 years.
Now I need to get on the phone with Ed U, to order some stuff.
