VIN 12306 'Auryn' : RHD twin turbo rebuild
Re: VIN 12306 'Auryn' : RHD twin turbo rebuild
Postby Admin-bloke » Fri Jan 04, 2013 6:32 pm
Starglider wrote:
Dan 6457 wrote:Another bttf car?? Maybe I should of kept my delorean afterall, as a standard one it will be getting rare at this rate!
As a side project I am designing an original, BTTF-inspired but quite different from the film car prop set. There is no question of 'screen accuracy', much of the detailing will be completely different.
Chris N has devised an impossibly cunning mounting scheme for this that (a) requires no new holes and (b) can be fitted and removed in under half an hour. As such this isn't a permenant conversion, it's something that could be added to the car for sci-fi conventions etc. Don't really have an ETA for this, probably some time after the actual car is done.
That will please our Darren-OEM-C and sounds like an interesting project there!
Postby Admin-bloke » Fri Jan 04, 2013 6:35 pm
MikeWard wrote:
Admin-bloke wrote:I'd rather buy oil and spark plugs and get the car running right ;)
:o Buy? You feeling ok? ;)
Ha ha cheeky, I nearly spat me tea out reading that....
Although it goes against my Yorkshire DNA, yes I would buy them (and not from Poundland either :shock: )
Postby bozzzydmc » Fri Jan 04, 2013 6:50 pm
Hey AB .. I still have that sieve and wire brush you lent me a while ago ... ;) x
Postby Starglider » Sat Jan 19, 2013 5:45 pm
Went over to the netherlands to see Ed Uding at DMC Europe, dropped off the engine from 12306 for twin-turbo rebuild, also picked up some new rear glass. He has a nice setup there;
Ed was great, gave me a piece of his mind on the PRV-6, turbos, supercharging, all the DeLorean vendors and what he thinks of them etc. Had a look at some parts he'll be using, the forged low-compression pistons, very short exhaust system etc. He had a car in there with his power steering fitted, which is pretty neat, although sadly it wasn't in a state that I could drive it.
Starglider
VIN #: 12306
Postby A Van » Wed Jan 30, 2013 9:51 pm
Nice bloke isn't he, do you have a completion date in mind?
Postby Starglider » Fri Feb 01, 2013 9:21 pm
A Van wrote:Nice bloke isn't he, do you have a completion date in mind?
Aiming for May at the moment.
Ed is making progress on the engine;
Starglider
VIN #: 12306
Postby arranj » Fri Feb 01, 2013 10:15 pm
Where's that picture of Tony holding the original of that intake - the very one this one was moulded off in fact!
Postby Starglider » Thu Feb 14, 2013 9:36 am
Ed has got the block cleaned up and coated;
Starglider
VIN #: 12306
Postby Admin-bloke » Thu Feb 14, 2013 1:23 pm
Now thar is one hell of a shiny bling motor !
Is it chromed or polished?
Postby Starglider » Thu Feb 14, 2013 5:02 pm
Admin-bloke wrote:Is it chromed or polished?
Chrome-effect powder coating. According to Ed it's more durable than actual chrome, at least for enclosed engine compartments.
Starglider
VIN #: 12306
