Peterbilt
Re: Peterbilt
Postby bozzzydmc » Fri May 10, 2013 12:27 pm
The headlights on a D are bad enough ... having the same on that big truck ?? !! ;)
Re: Peterbilt
Postby Dangermouse » Fri May 10, 2013 1:06 pm
Semi-truck accessories are big business for these overland truckers. Check out the shiny stuff at your local Chrome Shop:
http://www.empirechromeshop.com/s-1084- ... erior.aspx
including, interestingly enough, 12V 4x6 rectangular LED headlights
http://www.empirechromeshop.com/c-701-l ... ights.aspx
Re: Peterbilt
Postby delorean12uk » Sun May 12, 2013 8:20 pm
delorean headlight 1.jpg (150.37 KiB) Viewed 9985 times
we saw these at Battlesbridge car show today
delorean headlight 2.jpg (182.4 KiB) Viewed 9985 times
Another car with D headlights, although this one is probably more reliable!!!
Re: Peterbilt
Postby tourettes tony » Sun May 12, 2013 10:45 pm
Ok for headlights then :)
Re: Peterbilt
Postby Dangermouse » Sun May 12, 2013 10:50 pm
It's probably the one thing for a D that you can walk into a motor factors Stateside and pick up off the shelf. And have a choice.
So many cars had them in the 80s and 90s. Even imports had to be retrofitted with them.
Re: Peterbilt
Postby jerzybondov » Sat Jun 22, 2013 12:05 am
Bet no-one's ever seen one of these before...
http://jalopnik.com/the-1979-rsx-rally- ... socialflow
Also sporting DeLorean headlights you'll notice...
Re: Peterbilt
Postby RobvdVeer » Sat Jun 22, 2013 9:23 am
jerzybondov wrote:Bet no-one's ever seen one of these before...
That's ugly.
Re: Peterbilt
Postby jamesrguk » Mon Jun 24, 2013 9:13 pm
tourettes tony wrote:Ok for headlights then :)
You're all forgetting the beauty that is the Dennis Elite 6x2 refuse truck, which wears the same high power head lamps.
Such wonderful sporting heritage our cars have :shock:
Re: Peterbilt
Postby A Van » Mon Jun 24, 2013 9:14 pm
Wow yes the Dennis!
