Sound isolation (Silent Coat)
Postby RobvdVeer » Thu May 08, 2014 10:26 am
Now that the seats are out, I'm planning on cleaning up the carpet while i'm at it.
Years back i've been researching on using Dynamat in the cabin, but abandoned that plan for it being too expensive. I just stumbled on a new material called Silent Coat, which is way cheaper.
[youtubeHD]https://www.youtube.com/watch?v=h1P4L7TwV9Q[/youtubeHD]
It's about 4 m2 which should be more than sufficient for about £89 UK (http://www.caraudiodirect.co.uk/silent- ... on-2mm-mat) or €119 Netherlands (http://www.navishop.nl/silent-coat-extr ... 13296.html)
Any experience with it?
Re: Sound isolation (Silent Coat)
Postby ALEXAKOS » Thu May 08, 2014 1:22 pm
do those come as a female suit?
I need some silencers for my wife....
Postby RobvdVeer » Mon May 12, 2014 8:35 pm
Here's the plan. I'll be ordering 2mm and 4mm sheets. Put 4 mm on the floor and footwell area to minimize most of the road noise. I'll put 2mm sheets on the sides (shifter tunnel) and under the seats (so the seat rails sit good, as well as the seat itself absorbs a lot of sound. Then put 4mm on the wood panel behind the seat. If i have some left, i will put that on the rear firewall later on.
I calculated i'll be needing about 4 m2 in total.
Total price around €129.
Rob
Postby RobvdVeer » Sat May 17, 2014 8:19 pm
Stuff has arrived. Perhaps i ordered a bit too much, but i hate having not enough while halfway.
Postby RobvdVeer » Wed May 21, 2014 3:51 pm
Started work on the sound isolation. I did all this in one hour (easy does it). It is already noticable when i just shut the door.
Postby RobvdVeer » Wed May 21, 2014 6:42 pm
I call it a good day.
Postby Admin-bloke » Wed May 21, 2014 7:09 pm
Looking very professional there Rob :D
Postby RobvdVeer » Wed May 21, 2014 7:17 pm
If you can wrap a newspaper around a baked fish, you can do this too. It is very easy.
And: I bought way too much.
Postby RobvdVeer » Wed May 21, 2014 8:18 pm
Ok, just for a tryout I put in the carpet, the seat and the new DMC floor mat. All the holes still match up! (this means I didn't fuck up).
Postby RobvdVeer » Thu May 22, 2014 8:06 pm
today's progress.. cleanup.. Which means i'm done!
Tomorrow: install the seats. Now: a drink and the last remaining hour of The Desolation of Smaug.
todays progress
