Front Passenger Dash Trim wanted
Postby jogesh153 » Mon Jul 21, 2014 9:19 pm
Replacement Trim Wanted.JPG (51.44 KiB) Viewed 6319 times
jogesh153
VIN #: SCEDT26T6BD003802
Re: Front Passenger Dash Trim wanted
Postby ALEXAKOS » Tue Jul 22, 2014 10:13 am
back or gray?
Postby jogesh153 » Wed Jul 23, 2014 8:12 am
Black
jogesh153
Postby RobvdVeer » Wed Jul 23, 2014 11:07 am
Just asking, do you need the complete trim, or is it damaged? Because i retrimmed mine for less than $20, and it's hardly noticeable.
Postby jogesh153 » Wed Jul 23, 2014 12:30 pm
Hi Rob,
The metal studs have come out and it keeps dropping of the front dash, if they are not too much money I may buy new or used. Also the trim is peeling off.
jogesh153
Postby Admin-bloke » Wed Jul 23, 2014 3:47 pm
Does it look like you can add riv nuts and studs to fix your original panel?
Postby ALEXAKOS » Wed Jul 23, 2014 5:26 pm
will have a final on that soon;)
Postby jogesh153 » Sat Jul 26, 2014 10:46 am
Admin-bloke wrote:Does it look like you can add riv nuts and studs to fix your original panel?
yes maybe where can I buy the studs?
Also have centre console centre switch missing, not sure what it controls.
Also the drivers side door window does not open
jogesh153
Postby ALEXAKOS » Sun Aug 03, 2014 1:43 pm
If your black leather is decent, I have found one for 150usd that is in good condition without the leather.
Postby A Van » Tue Aug 05, 2014 8:10 pm
Which studs are you missing?
