Fuel injectors
Fuel injectors
Postby RobvdVeer » Sat Sep 27, 2014 8:26 pm
Hi guys,
I'm up for 6 new fuel injectors. Ed has them on backorder, so meanwhile I'm investigating my options.. At least 3 are due for replacement so i'm taking Ed's advise to stop mucking about and replace them all at once.
So far I've only found SpecialT selling them. But basically I am completely done with getting stuff from the USA. Every time I shop there I get bombarded with import taxes and insane shipping costs to be payed on delivery, making stuff over 100% more expensive and somewhere else.
Re: Fuel injectors
Postby Chriss » Sat Sep 27, 2014 8:43 pm
Try http://www.kmipetrolinjection.co.uk/Bos ... tronic.htm
Re: Fuel injectors
Postby Admin-bloke » Sat Sep 27, 2014 9:46 pm
Admin-bloke wrote:
RobvdVeer wrote:Ed has a 24v renault engine for a client, you mean that one?
My injectors are just bad and aged because of low usage. Rust has formed and cleaning them won't help in the long run.
I'll have a go at cleaning them Rob. I've done one or two.
Your car is looking great by the way :thumbsup:
viewtopic.php?f=41&t=436&start=670
Re: Fuel injectors
Postby RobvdVeer » Sat Sep 27, 2014 9:48 pm
I'm not sure why you refer to my resto blog there...
Ignore that: bloody tapatalk
Re: Fuel injectors
Postby Admin-bloke » Sun Sep 28, 2014 10:07 pm
Rob, I've had a look in my stock and I have 2 spare working tested injectors. I sent Bandit 2 to (try to) sort his over fueling out. He only needs one, so that would make 3 :)
Fully tested by me on the bosch injector tester.
Yours if you want them :D
Re: Fuel injectors
Postby RobvdVeer » Sun Sep 28, 2014 10:13 pm
Yes yes yes please can i try them?
Re: Fuel injectors
Postby Admin-bloke » Sun Sep 28, 2014 10:28 pm
For you Rob, if you wanted to send me your old ones I'll test / clean the lot, but if you want to try these ones of course you can. I'll need to get the 3rd injector from Bandit first (probably at euro tec October) and I'll post them to you.
Re: Fuel injectors
Postby ALEXAKOS » Mon Sep 29, 2014 9:17 am
Hey AB can I send you my old lot including the start valve? Is yes, drop me your address per pm.
Re: Fuel injectors
Postby RobvdVeer » Mon Sep 29, 2014 10:14 am
Thanks for the help, Nick, you are awesome
Re: Fuel injectors
Postby Admin-bloke » Mon Sep 29, 2014 5:25 pm
RobvdVeer wrote:Thanks for the help, Nick, you are awesome
No problem Rob :D
