Non-working metering head wanted
Re: Non-working metering head wanted
Postby Admin-bloke » Fri Oct 24, 2014 9:00 am
Sorry, I've checked the part number and the one I have is actually a volvo one. ...
Postby dmc4087 » Fri Oct 24, 2014 9:31 am
Thanks anyway Mr T
Postby A Van » Fri Oct 24, 2014 10:34 am
Ah I haven't checked part numbers what do I need to look for
Postby ALEXAKOS » Fri Oct 24, 2014 10:45 am
I presume this is the DeLorean number on the head Al;)
Postby delorean12uk » Fri Oct 24, 2014 10:57 am
you won't need a part number, the Delorean metering head has an extra port on it where the supply and dump lines go and easy to identify
Postby ALEXAKOS » Fri Oct 24, 2014 10:58 am
ALEXAKOS wrote:Image
Right Jason...
As seen on the above image the delorean has 4ports on one side and the volvo has 3
Postby dmc4087 » Fri Oct 24, 2014 11:24 am
Yep the part number ends in 109 and it has the 4 ports on one side. Thanks!
Postby A Van » Fri Oct 24, 2014 12:45 pm
Ok thanks for info
will take a look, I suspect its Volvo
Postby A Van » Mon Oct 27, 2014 10:48 am
Looks like I have a DeLorean one !
Postby ALEXAKOS » Mon Oct 27, 2014 12:58 pm
Yup that is a delo one Al. For now he is covered. Just sent him mine to Ed for refurbishing.
