There is a wealth of info on this forum, as Andy mentioned he was good enough to post up his findings on real seals. On the clutch front find a Renault specialist, not main dealer, for the clutch alignment tool as Renault used to supply one in their 3 piece kit or failing that talk to Kevin or Lee @ GTO.
http://www.deloreaneurotec.co.uk/forum/viewtopic.php?f=19&t=4056
http://www.deloreaneurotec.co.uk/forum/viewtopic.php?f=12&t=4104&p=54591&hilit=rear+seal#p54591
Is your rear main seal leaking at all? A wise mechanic once told me if its not broke don't fix it but understand the sentiment as your already in there. Worth getting your flywheel skimmed over while your there too in the case.
BTW Rob Grady is/was selling struts at a discount for Christmas, might be worth checking out
http://www.pjgrady.com/product/lift-piston-set/
On the stainless front have you spoken with Chris Nicholson? He might be able to help, his work is amazing!
