Vin 6511 - Dan's 2nd Delorean
Postby Dan 6511 » Sun Jan 18, 2015 6:46 pm
Done a bit of stripping down this weekend:
Next job is to get the arms stripped and weld on plates to re-enforce them but that can wait till next weekend now.
Postby RobvdVeer » Sun Jan 18, 2015 6:47 pm
looks familiar doesn't it
Postby Dan 6511 » Sun Jan 18, 2015 7:07 pm
Yes Rob, done the very same thing to my first car! Nothing like doing a job twice :roll:
I am thinking about modifying the front arms the same way that Jason Monk has done to his, but I can't find where on here he put the pics...
Anyone want a pair of stock ride height front springs? :lol:
Postby MikeWard » Sun Jan 18, 2015 7:29 pm
Dan 6511 wrote:I am thinking about modifying the front arms the same way that Jason Monk has done to his, but I can't find where on here he put the pics...
viewtopic.php?f=20&t=3392 :thumbsup:
Postby dmc4087 » Mon Jan 19, 2015 4:19 pm
Would it not be easier to go for Ed's lca supports?
Postby Dan 6511 » Mon Jan 19, 2015 5:06 pm
They would help but you still get some flexing, and I'm not a fan of polybushes. They maybe better if they were solidly mounted to the arm and only had bushes where they pivot on the chassis.
I personally think Jason's idea is a better solution making a proper wishbone.
Postby dmc4087 » Tue Jan 20, 2015 11:58 pm
Dan 6511 wrote:They would help but you still get some flexing, and I'm not a fan of polybushes. They maybe better if they were solidly mounted to the arm and only had bushes where they pivot on the chassis.
Ah right I see.
If my frame wasnt galvanised/powdercoated already, I'd consider going down the proper wishbone route then.
Postby Dan 6511 » Mon Apr 13, 2015 9:54 am
Time for a bit of an update as I've been doing some more work.
I decided not to bother modifying the suspension setup in the end because basically I couldn't be bothered and just want the car back on the road now.
Arms shot-blasted and then cut out strengthening plates:
All welded up and powdercoated:
Retaining rings pressed into place:
New Delorean Club balljoints pressed in:
New bushes pressed in:
All assembled with DPNW sway bar bushes as well:
Back on the car with new Delorean Europe front springs:
Postby A Van » Mon Apr 13, 2015 10:44 am
Looks great Dan
Postby MikeWard » Mon Apr 13, 2015 11:32 am
Looking good there Dan, nice work!
