imported from tennesse, to norfolk.. restoration begins!
Re: imported from tennesse, to norfolk.. restoration begins!
Postby mec » Fri Apr 17, 2015 12:57 am
I'm thinking mine might be a bit like that when i eventually get the body off :shock:
Postby carl hammond » Fri Apr 17, 2015 8:47 pm
More chassis restoration pics...
Postby clocktown64dd » Fri Apr 17, 2015 9:03 pm
Thanks Carl for posting! I will get round to getting sorted from my laptop, can't seem to post photos from phone :( it's nearly done, few more bits to weld then got to put it on the car and do the rear end.
clocktown64dd
Postby arranj » Fri Apr 17, 2015 10:42 pm
Download an app called 'tapatalk' - you can post photos then :)
Postby Dan 6511 » Sat Apr 18, 2015 12:14 am
Nice welding there :D
Postby A Van » Sat Apr 18, 2015 7:10 am
That's what I thought Dan, very neat
Postby clocktown64dd » Sat Apr 18, 2015 8:16 am
The top section has been made from 2 pieces with a strip around the front so it's hollow, strong but still lightweight. I've prepped the edges and done a full pen weld so its internally welded and I've sanded off the top weld so it looks smooth and you can't tell it was welded, I'm very pleased with it, should hopefully get it fitted today! :)
clocktown64dd
Postby Dan 6511 » Sat Apr 18, 2015 10:03 pm
What welder are you using?
Postby clocktown64dd » Sun Apr 19, 2015 11:27 am
It's a TIG plant that i borrow from work sometimes :)
It's on the car now tacked in ready to be welded. Can't believe what a difference it's made to look at. Il have pictures up soon of this latest progress.
clocktown64dd
Postby carl hammond » Sun Apr 19, 2015 2:44 pm
Did somebody say more pics? ;)
