Vin 000569 back up n running
Re: Vin 000569 back up n running
Postby BABIS » Fri Jun 05, 2015 6:55 pm
she looks great ;)
BABIS
Postby Dan 6511 » Fri Jun 05, 2015 9:33 pm
Looks good..... for a delorean ;)
Postby Dukes Of Hammond » Fri Jun 05, 2015 10:08 pm
A Van wrote:I don't think there is an accurate colour match for the dark grey ones mate
Maybe go for a color close to the fascia ...
Alan Hammond
http://www.deloreanclub.uk/
Dukes Of Hammond
VIN #: 569
Postby Dukes Of Hammond » Fri Jun 05, 2015 10:11 pm
A Van wrote:You might want to fix that air leak as well
Yeah ... When I block leak... Engine increases revs a little... I need a new Plug for it.. .. And then I'm guessing decrease revs at adjuster..
Alan Hammond
Dukes Of Hammond
VIN #: 569
Postby Dukes Of Hammond » Fri Jun 05, 2015 10:14 pm
Thanks everyone for support... My Delorean enthusiasm has returned... When it is back on the road it will look the best it ever has!.. Having Chris N re-brush and wheels painted dark grey..
Alan Hammond
Dukes Of Hammond
VIN #: 569
Postby Dan 6511 » Fri Jun 05, 2015 11:37 pm
Dukes Of Hammond wrote:When I block leak... Engine increases revs a little... I need a new Plug for it.. .. And then I'm guessing decrease revs at adjuster..
Probably a mix of the idle screw and the fuel/air mixture. Get it on an exhaust tester, standard MOT one is fine, and set mixture and then if revs still high then adjust idle speed, if that sods up the emissions then adjust mixture again. Eventually you'll get sweet spot with nice idle and correct emisions. Nick T will probably chime in with what the emissions should be on a stock car with no cat. Also make sure when at idle the microswitch is being closed properly.
Postby Dukes Of Hammond » Fri Jun 05, 2015 11:45 pm
Micro switch switches on shut down fine... Maybe Nick T can give her a tune up when she's on the road :)
Alan Hammond
Dukes Of Hammond
VIN #: 569
Postby Dukes Of Hammond » Sat Jun 06, 2015 7:55 am
The work continues ;)
Alan Hammond
Dukes Of Hammond
VIN #: 569
Postby Dukes Of Hammond » Sat Jun 06, 2015 7:57 am
Do you know if we have a re-stock of metering flap bungs? Thanks!
Alan Hammond
Dukes Of Hammond
VIN #: 569
Postby arranj » Sat Jun 06, 2015 8:09 am
If you can tell me the part number by the end of the weekend then I'll ask Ed to bring one
