Project 3193
Project 3193- 5 YEARS LATER
Postby Dave T » Fri Nov 20, 2015 11:05 pm
Thought this post totally worthy of an update to say the least a 'Mammoth' nut & bolt restoration. The car is now located in Ireland. After purchasing from Dave (Inox) I intend to take it over the finish line.
The car is now running , started straight up :thumbsup: .... just a tidy up of the wiring before the interior goes back together. A more detailed description of this Nut & Bolt Resto can be found on the Delorean Ireland Forum.
engine bay right.JPG (126.51 KiB) Viewed 4525 times
underside rear left.JPG (78.09 KiB) Viewed 4525 times
pipes , hoses, brackets all spanking new
underside coolant rail.JPG (81.93 KiB) Viewed 4525 times
engina bay.JPG (89.99 KiB) Viewed 4525 times
Replacement low mileage Volvo engine ,all new seals , plugs, leads , clutch kit , switches etc etc etc etc.......etc
engine bay left.JPG (84.37 KiB) Viewed 4525 times
shot blasted & painted super clean finish , exhaust newly wrapped in stainless
engine underside.JPG (93.61 KiB) Viewed 4525 times
Dave T
VIN #: 2030
Re: Project 3193
Postby A Van » Sat Nov 21, 2015 7:14 am
Looks a great job
Re: Project 3193
Postby InoX » Sat Nov 21, 2015 10:39 am
Excellent.
InoX
Re: Project 3193
Postby Admin-bloke » Sat Nov 21, 2015 11:03 am
Looking great. Keep up the good work :)
Re: Project 3193
Postby Domi » Sat Nov 21, 2015 2:12 pm
That's so clean, i like it, very good job :)
Re: Project 3193
Postby delorean12uk » Sun Nov 22, 2015 3:58 pm
Looks impressive!!!
engine bay right-1.JPG (109.85 KiB) Viewed 4471 times
I have one of these if you need it, as I'm sure your aware it's a Vacuum pump for the brake servo. It's been sitting in my garage for years
Re: Project 3193
Postby Dave T » Sun Nov 22, 2015 5:54 pm
Super ...Thanks for the offer & the kind comments :thumbsup:
I have a spare one too in the garage :D .... I think the vacuum pump is a good addition to the D should make the brakes more punchy.
I maybe calling on the help of you guys as there are 'lots' of interior trim & door trim missing , no doubt someone has something thrown in the corner of the garage ... likewise if anyone needs a part would be glad to help out.
Dave T
VIN #: 2030
Project 3193
Postby A Van » Sun Nov 22, 2015 7:08 pm
Good spot Jason, what variation of the PRV carries this servo then
Re: Project 3193
Postby Dan 6511 » Mon Nov 23, 2015 3:16 am
Both my 760s had the vac pump. Never thought about actually using it on the delorean though.
Re: Project 3193
Postby delorean12uk » Mon Nov 23, 2015 6:02 pm
This come off of Tysons 760 that is now in James RG's car. Unfortunately I think I have scrapped the rocker cover that it bolts to as it has a hole in it, but the cam has the lob on it ready for a vac pump to be fitted. It would be interesting if it made any difference to the brakes on a D. The best brakes on a Delorean that I have ever driven was Dan Shanes old one, the brakes were spot on!!! But saying that my I pretty punctual now after a few tweeks here and there
