Well since my car came of the road in late 2015 followed by me stripping the engine down to its component parts, not a lot happened with it as life got in the way; lots of travel for work, and a house move etc etc. The new house has a double garage and workshop ready for the D work to commence when time allowed. Anyway with the Hamburg trip announced I really wanted to get the up and running again. My engine is still in bits, and it wasn't looking like I'd have enough time to rebuild it, but then a fellow club member happened to have a 2.7 engine out of a Renault going spare and for sale. So this seemed like a good solution to get the car back together again and take my time rebuilding my 2.8 engine for a swap next winter perhaps. I could also use it to test out my collection of Volvo ignition/fuelling gear.
So the car was finally got out of storage, dusted off and moved over to my house
- 01.jpg (160.63 KiB) Viewed 14556 times
The temporary Renault engine
- 02.jpg (169.73 KiB) Viewed 14556 times
Thanks goes to mec for collecting the engine for me whilst he was transporting his own chassis around the country.
- 03.jpg (125.7 KiB) Viewed 14556 times
- 04.jpg (131.11 KiB) Viewed 14556 times
Engine bay cleaned up, and some damaged areas of the epoxy ground out and repainted with POR 15.
- 05.jpg (136.01 KiB) Viewed 14556 times
Renault engine scrubbed up and Delorean pulley fitted.
- 06.jpg (126.99 KiB) Viewed 14556 times
Gearbox refitted. This was done twice as it was discovered that the person who rebuilt the box used a 2nd hand gasket, so it came back out and new gasket and oil seals from Delorean Go were installed, then the gearbox re-fitted.
- 07.jpg (129.85 KiB) Viewed 14556 times
Renault lump going in.
- 08.jpg (93.66 KiB) Viewed 14556 times
Wiring and plumbing going on.
- 09.jpg (139.53 KiB) Viewed 14556 times
- 10.jpg (131 KiB) Viewed 14556 times
All plumbed in, but will it actually run.... Thankfully it did
- 11.jpg (94.5 KiB) Viewed 14556 times
Driveshafts rebuild with new grease and CV boots.
- 12.jpg (86.4 KiB) Viewed 14556 times
Rear end all back together and driveshafts going in.
- 13.jpg (93.04 KiB) Viewed 14556 times
New set of Julian's fuel lines installed.
- 14.jpg (143.03 KiB) Viewed 14556 times
New stainless free flow exhaust fitted. This was purchased before the car came off the road so it was nice to finally get it on the car.
- 15.jpg (123.37 KiB) Viewed 14556 times
Wheels refurbished by Lepsons, as recommended by other club members. Very nice finish on them.
- 16.jpg (151.58 KiB) Viewed 14556 times
And finally a Mike Ward approved front numberplate.
- 17.jpg (124.38 KiB) Viewed 14556 times
I have also now replaced the fuel accumulator and now it holds pressure and starts from hot which it never did before.
Now the next challenge is the Hamburg trip...
