Postby DJK73 » Mon Feb 22, 2016 9:52 pm
Heh Domi where did you get the banjo bolt kit from?
Dan
Dbro4
Ex Vin#10223
Grey interior, Manual
Free flow
DJK73
VIN #: 10223
Postby Domi » Mon Feb 22, 2016 10:22 pm
Postby arranj » Tue Feb 23, 2016 3:55 pm
I'm putting together a low price stainless kit of those bolts Dan, with washers - should be done within a week I think.
Postby Domi » Sun Feb 28, 2016 7:10 pm
New wire, longer and bigger from the starter to the alternator
New silicone pipe to the stainless pipe
Put all the red silicone vacuum line in place
I wonder how you tight this part? Do I need a special tool? Thanks!
Postby Domi » Wed Mar 02, 2016 9:00 pm
Old fuel line from the frequency valve removed
New stainless fuel line, let’s hope everything is okay with the clamp
Go back into the engine compartment
Postby andyd » Wed Mar 02, 2016 9:14 pm
Domi wrote:New stainless fuel line, let’s hope everything is okay with the clamp
Great work Domi!
I am not sure how high the pressure is on the line to the frequency valve is, but if you are concerned, screw drive fuel clips may be better than the spring type clips you have here?
Postby Domi » Wed Mar 02, 2016 9:42 pm
No pressure in this pipes, but I guess you're right I'd better change them.
Postby Domi » Mon Mar 07, 2016 7:15 pm
Finally decided to change them
Postby Domi » Fri Mar 11, 2016 10:29 pm
Water pump is back into the engine compartment
New belt and screw
Only one pipe on two, such a pain to put them back. I thought silicone pipes were easier to mount, but no...
Postby mec » Sat Mar 12, 2016 1:52 am
coming along nicely ! :thumbsup: :thumbsup: :mrgreen:
Users browsing this forum: No registered users and 28 guests
