thanks guys time to get back to the D, when i got it home it was obvious there was an oil leak problem on the left side of the engine as there was 20 odd years of oil, dirt and shit stuck to the engine which i cleaned off to see where the leak is coming from and this is what i found
- DSC_0875.JPG (835.45 KiB) Viewed 4167 times
- DSC_0876.JPG (849.79 KiB) Viewed 4167 times
obviously an expert was here before me
- DSC_0873.JPG (932.72 KiB) Viewed 4167 times
- DSC_0874.JPG (638.79 KiB) Viewed 4167 times
fixed with my first club part order
- DSC_0879.JPG (674.05 KiB) Viewed 4167 times
- DSC_0880.JPG (764.01 KiB) Viewed 4167 times
next up is to get rid of this thing, sorry if you like it but this the worst thing you could do to a delorean, it's guaranteed to make your gear changes terrible and stuff your gear stick
- DSC_0889.JPG (494.3 KiB) Viewed 4167 times
nothing wrong with the classic look
- DSC_0890.JPG (792.94 KiB) Viewed 4167 times
time to fix the non working speedo, nothing wrong with the speedo drive at the front wheel but the upper cable was cross threaded to the lamda box and that wasn't it's only problem
- DSC03125.JPG (4.11 MiB) Viewed 4167 times
- DSC03126.JPG (3.74 MiB) Viewed 4167 times
on to more mechanical stuff next
