VIN 17005 New Zealand
Re: VIN 17005 New Zealand
Postby Admin-bloke » Fri Jun 17, 2016 6:23 pm
They look great Gary :thumbsup:
Postby gary290 » Fri Jun 17, 2016 9:22 pm
thanks guys, the plating looks a bit out of place on an old dirty engine but so be it,
also i've found a simple way of lowering the rear springs without cutting or buying new shocks,
just re groove where the the spring sits on the shock, this is the original
and re grooved at 1" and 1 1/2" lower
gary290
VIN #: 17005
Postby gary290 » Tue Sep 13, 2016 2:48 am
Next job is to sort out the front springs, the 4 wheel drive look is awful and makes the car look stupid, i think these cars need to look more normal
club springs vs original
while i was there i didn't like the look of the bottom spring bushes
so got some poly bushes and made some spacers to suit
gary290
VIN #: 17005
Postby Admin-bloke » Tue Sep 13, 2016 12:37 pm
That looks brilliant :thumbsup:
Postby gary290 » Fri Mar 03, 2017 12:06 am
So after thinking that i'd fixed the leaking gearbox seals i found they were leaking again, i thought i had installed the wrong seals so i got some from the club which are the same as my one's, but the flange has a bit of slop and the seal face is quite pitted so the only way to fix it is to press a speed sleeve on which did the job.
so now i can enjoy driving it for the summer
gary290
VIN #: 17005
Postby dmc4087 » Fri Mar 03, 2017 2:46 pm
That's sitting nicely now. Haven't seen that rear spring mod before, nice one.
Postby gary290 » Fri Mar 03, 2017 8:43 pm
this what i started with
gary290
VIN #: 17005
Postby A Van » Wed Mar 08, 2017 8:18 am
Great mod!
Postby gary290 » Thu Mar 30, 2017 8:44 am
after a good day out at the Brit & Euro car show here in Auckland NZ with my friends bttf car
i got home to find my reverse lights were on without being in reverse, so i thought it would be the gearbox switch which has been dicked with before and purchased a new one from the club, after installing it i still have the same result, out of the gearbox in hand the lights are on and when i push the switch in the lights turn off, i have tried another switch from an old Mazda and it works as it should, have i got two dud's or is this an issue with the D?, previous to this the lights worked as per normal, anybody had this problem or can anyone help please?
gary290
VIN #: 17005
Postby gary290 » Tue Jul 25, 2017 10:49 pm
i've sorted the reverse switch issue, the switch is always pressed so the lights stay off and when reverse is engaged the switch is depressed turning the lights on (encase anybody was interested) the fix was to remove the sealing washer and it all works as it should.
next job is to bolt down the rear roof box as it is lifting and has pushed out and broken the plastic covering panel above the rear window
some muppet has put rivets in
and the front part has a little rust
i have taken the torsion bars out without the need for a pile of wood and extension bars, it's not as complicated and difficult as others have made it out to be, this is what i did:
you will need a helper so you have 2 hands free,
very simply unhook the strut and prop the door up as far as it will go with some wood, get the helper to take the remaining tension off the bar, undo the 2 m8 bolts and slide the retaining plate on to the tool your using, slowly release the remaining tension on the rod and your done,
the tools i used were a 1/2" power/breaker bar, 3/8" hex to 1/2" drive bit, 13mm spanner, 2m length of wood and the handle off the trolley jack to make it easy if your helper is short
don't be put off by some of the stories and comments on doing this job, it's a lot easier than you think
gary290
VIN #: 17005
