Thanks to Spudmurphy I have got on to fixing my rad fans and shroud, for whatever reason the po cut the shroud in half and binned it with one of the fans, so when Spud was about to chuck his broken shroud so i thought i could make it work for me
- DSC_1220.JPG (1.18 MiB) Viewed 5977 times
- DSC_1222.JPG (1.19 MiB) Viewed 5977 times
the po did such a crap job they even cut the warning sticker in half!
all the rad brackets were bent out of shape and missing bolts etc...
i bought 2 new fans and had the shroud fixed and glassed together, it's a bit rough but i'm happy with it and it's under the car anyway
- DSC_1255.JPG (613.19 KiB) Viewed 5977 times
- DSC_1256.JPG (653.77 KiB) Viewed 5977 times
- DSC_1257.JPG (745.22 KiB) Viewed 5977 times
- DSC_1258.JPG (746.25 KiB) Viewed 5977 times
- DSC_1263.JPG (568.16 KiB) Viewed 5977 times
also the po removed the fan relay and stuffed in a wire with a switch and this is how the fans operate now, so i think the system isn't working properly, any ideas?
thanks again to Spud for helping me get this sorted
