Postby gruffalo » Sun Sep 10, 2017 8:21 pm
Oh, sorry for your unfortunate incident.
You're unable to turn the steering wheel even after you got the ball joint back in place?
Postby Domi » Sun Sep 10, 2017 8:32 pm
No impossible to turn the steering wheel..
It turn, but not the wheels :(
I'll check this later...
Postby InoX » Sun Sep 10, 2017 8:59 pm
sorry to hear about this. I know the feeling you spend months and months on it and it doesn't repay you just kicks you in the teeth for all the hard work.
Hope you get it going again soon, pal. :thumbsup:
InoX
Postby Domi » Sun Sep 10, 2017 9:10 pm
Thanks, I already ordered two new UK ballpoint to replace the faulty one...
I have to see what other parts failed.
Postby MikeWard » Mon Sep 11, 2017 8:01 am
Didn't you have some on the shelf already, or did you sell that pair? viewtopic.php?f=41&t=84&p=71221#p71221
Postby cis6409 » Mon Sep 11, 2017 3:00 pm
That's bad luck !it could have been alot worse .. Don't give up you've come really far!
Hopefully it ll be a quick fix :thumbsup:
Postby Domi » Mon Sep 11, 2017 6:16 pm
MikeWard wrote:Didn't you have some on the shelf already, or did you sell that pair? viewtopic.php?f=41&t=84&p=71221#p71221
You're right, I bought these a long time ago before the arm.
Like I didn't find someone to mount the new one on the arm, I sold them half price to someone... if only I knew :(
Postby Domi » Mon Sep 11, 2017 6:17 pm
cis6409 wrote:That's bad luck !it could have been alot worse .. Don't give up you've come really far!
Yes, it could be worse if i was driving at high speed...
I won't give up, but i need to find some strength to do it again...
Postby Domi » Mon Sep 11, 2017 6:27 pm
Here is a video of my steering rack:
https://youtu.be/Xwq-M7pLouk
Some pictures of the ball joint as request by Arran on Facebook:
Forget the nut, this one is just for getting home
Postby arranj » Mon Sep 11, 2017 6:54 pm
I have an idea which ones it could be, if you could possibly read or photograph any markings on the rubber bit it would help - I can compare against my library of ball joint photos :) The markings might be in 2 places, and very faint though, so might have to wait until they are off the car. But I'm not sure the ball joint is at fault here.
