Postby andyd » Mon Sep 11, 2017 9:28 pm
Definately different ball joints to those pre-installed the Swingle arms I bought in 2016.
viewtopic.php?f=41&t=4690&start=40
He advised caution when replacing bj's in ally arms.
Will be checking mine asap! Good luck Domi.
A
Postby Domi » Mon Sep 11, 2017 9:38 pm
Daniel Shane wrote:Are you using any anti galvanic compound between the steel ball joint and the Ali arm ?
No, nothing at all.
Postby Domi » Mon Sep 11, 2017 9:42 pm
andyd wrote:Will be checking mine asap! Good luck Domi.
Many thanks ;)
Postby Daniel Shane » Mon Sep 11, 2017 9:57 pm
No, nothing at all.
You really should. Otherwise the Ali will dissolve over time. A smear of Duralac is really needed.
I've seen plenty of Ali eaten away by this type of differing metals placed together. Early lotus Elise uprights are a great example
Dan Shane
DCUK 008
Ex VIN 4754
The Black Stig
Daniel Shane
VIN #: Ex 4754
Postby mknowlton » Mon Sep 11, 2017 9:57 pm
Ok,
I think I can see what might have happened here
The washers have been fitted with all good intentions but it is likely that they have accidently been trapped between the nylock nut and the shoulder at the top of the taper.
This being the case then this was the tightness that you felt when doing up the nut with a wrench as opposed to the tightness of the taper in the hole.
Just a few minutes driving would be enough for the washers to become free and the nuts to undo until one separated and the other was almost undone.
It is the only reason that I can think of why both would come undone so quickly.
Anyway, the most important thing is that you are ok Domi and hopefully it is not too big a job to put right.
I would personally leave the washers out when you fit the new ones that Arran is sending.
I hope this helps
Mike Knowlton (DBro 1)
DeLorean DMC-12, VIN#4208,
mknowlton
VIN #: 04208
Postby Domi » Mon Sep 11, 2017 10:10 pm
Daniel Shane wrote:You really should. Otherwise the Ali will dissolve over time. A smear of Duralac is really needed.
Thanks for the advice :)
Postby Domi » Mon Sep 11, 2017 10:12 pm
mknowlton wrote:I would personally leave the washers out when you fit the new ones that Arran is sending.
I hope this helps
All right, thank you very much for the good advice ;)
Postby Domi » Tue Sep 12, 2017 7:56 pm
Get ready for another hours of fun under the car :roll:
Fortunately, the damage on the lower arm are minor
Postby DJK73 » Wed Sep 13, 2017 5:13 pm
Look on the positive side Domi, imagine the mess it would of made to standard LCAs
Lucky you have the aluminium arms, shows that they are very strong and well worth the investment
Dbro4
Ex Vin#10223
Grey interior, Manual
Free flow
DJK73
VIN #: 10223
Postby Domi » Wed Sep 13, 2017 6:33 pm
Yes absolutely, you're right :)
