by gruffalo » Fri Feb 23, 2018 9:39 pm
Ok, I need some advice...
Engine 1
The original engine in my car has 13.000miles but sat for a long time. It had water in the cylinders and intake ports, it turned out. Rust in 3 cylinders, rusty valve seats and stems. I figured I’d run it for a season and see what happened. Well, it wouldn’t run properly, and I recently discovered it had a bent intake valve on #3. Cams have no visible wear, and there’s no oil sludge in the valve covers.
Engine 2
B28E, sat outside for a long time. Had moisture in the valve covers, so the cams are pitted by rust, and somewhat worn. Cylinders also have rust.
Engine 3
B28E, my recent purchase. Unknown mileage. Sat in dry storage for many years. Valve stems and seats look clean, so hopefully the cylinders are ok. But the valve covers were full of oil sludge, and the cams are unfortunately crazy worn. And who knows what else the apparently poor oil quality and maintenance led to.
My initial plan was to go all in on the recent B28E purchase, get all the correct Volvo parts, and go all in on a full euro spec B28E. However the worn valve train has me got doubtful.
I could swap the good dmc cams into the B28E, but then it would be a compromise, and I wonder if it’s worth it spending money on refreshing the Volvo fueling and ignition bits, when I don’t have the correct cams.
Any thoughts?
Magne
- Attachments
- Worn cam
- 6E0C6878-1D56-449A-83A3-5BAD0895F5EA.jpeg (1.97 MiB) Viewed 4104 times
